Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
leafuntec, wolf777, Smittyzzz, JimBobSeeker, Joey737
69902 Registered Users
51 registered members (AurionX2, Amkeer, Aichiguy, 77GrandPrix, 2015_PSD, 65convertible, 5 invisible), 870 guests, and 17 spiders.
Topics297,573
Posts5,118,290
Members69,902
Most Online3,589
Nov 2nd, 2019
Page 1 of 4 1 2 3 4
Plumbing question #5108741 05/18/19 06:57 PM
Chris142 Offline OP
My wife flushed her glasses down the toilet! I immediately went outside to the clean out. I put a screen in the pipe. I then poured about 30 gallons of water down the toilet. I used a bucket full of water. I did not catch anything in my screen.
When flushed does the "stuff" go immediately into the septic tank? Or does it slowly move down the pipe with each flush?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Plumbing question [Re: Chris142] #5108746 05/18/19 07:00 PM
rsylvstr Offline
Immediate
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Plumbing question [Re: Chris142] #5108749 05/18/19 07:01 PM
O
oldhp Offline
O
Depends on how long the pipe is to the tank. If it was put in correctly with the figured out amount of slope, yes by the time you got there it was too late. You want the "stuff" to float with the flush water.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Plumbing question [Re: oldhp] #5108751 05/18/19 07:03 PM
Chris142 Offline OP
About 30 ft
Re: Plumbing question [Re: Chris142] #5108756 05/18/19 07:10 PM
PimTac Offline
If they are metal frames you could tie a magnet to some fishing line, open up that tank and go trolling.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Plumbing question [Re: Chris142] #5108757 05/18/19 07:11 PM
rollinpete Offline
Wire rim glasses will sink.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 189k miles
03 Saturn Ion 2.2 L4 5spd 240k miles
Shell Rotella gas and truck 5w30
PPHM 5w30
Currently under the influence of oil shocked2
Re: Plumbing question [Re: PimTac] #5108758 05/18/19 07:11 PM
rollinpete Offline
yep go fishing grin2
Pete.
PPHM 5w30
Re: Plumbing question [Re: Chris142] #5108759 05/18/19 07:12 PM
J
John_K Offline
J
My wife wouldn't wear them no matter what.
2009 Mercury Grand Marquis, 8 cyl auto, 93xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 99xxx miles, Maxlife/OEM Filter
Current oil stash: 459 qts.
Re: Plumbing question [Re: Chris142] #5108766 05/18/19 07:19 PM
rollinpete Offline
Just go fishing lol.
I wouldn't worry about my germs , it's the other guys germs I have a problem with. LOL
Pete.
PPHM 5w30
Re: Plumbing question [Re: Chris142] #5108768 05/18/19 07:20 PM
F
Farnsworth Offline
F
Try to visualize if the glasses are small enough to get through the trap. The curves are seen on the toilet outside, usually. I think they probably are in the toilet trap. If toilet is removed maybe they can be found.
Re: Plumbing question [Re: rollinpete] #5108770 05/18/19 07:23 PM
Chris142 Offline OP
Originally Posted by rollinpete
I would my germs don't bother me, it's the other guys germs I have a problem with. LOL
My wife is legally blind with out them! She can't see a thing. Can't drive,can't read etc. If I can find them I would wash them well,spray with lysol, maybe even run them in the dishwasher.
Re: Plumbing question [Re: Chris142] #5108772 05/18/19 07:25 PM
B
BigD1 Offline
B
Some times stuff like that will get stuck in the toilet. You can pull the toilet, and give it a shake or two to see if anything is rattling around. Just back flush it with a water hose until it comes out the way it went in. When my kids were growing up, I had to retrieve various items. One that stands out was a very expensive bottle of perfume.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Plumbing question [Re: BigD1] #5108793 05/18/19 07:41 PM
Dinoburner Offline
Most frames are nonferrous. Probably time an eye exam and new glasses.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Plumbing question [Re: Chris142] #5108799 05/18/19 07:46 PM
rollinpete Offline
Exactly now you have to find them.
hmmm
Pete.
PPHM 5w30
Re: Plumbing question [Re: Chris142] #5108804 05/18/19 07:50 PM
E
eljefino Offline
E
+2 take the toilet off. You'll need a new wax ring but they're $1.50. And it's as good a time as any to clean and fix the floor underneath.
Page 1 of 4 1 2 3 4
