F1 - 2019 French Grand Prix
by gofast182. 06/20/19 06:17 AM
Yard rollers
by dlundblad. 06/20/19 05:20 AM
EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
The cool people of Bitog
by Marco620. 06/19/19 08:52 PM
How do Adjust Your Seat and Mirrors
by buster. 06/19/19 08:37 PM
AC for hybrid and electric vehicles
by JimPghPA. 06/19/19 08:06 PM
Mobil 1 sold at Walmart vs Summit Racing
by kosoku. 06/19/19 08:02 PM
Troy Bilt TB200
by Floyd1. 06/19/19 07:54 PM
Cutting vinyl planking, Do I need a snapper?
by JLawrence08648. 06/19/19 07:13 PM
1969 Honda N600, Serial #1...
by mattwithcats. 06/19/19 06:02 PM
My Son Turned Me On to a New Cooking Show
by NYEngineer. 06/19/19 05:42 PM
Naphthenic Oils
by MolaKule. 06/19/19 05:06 PM
Mopar 5W-20?
by John344. 06/19/19 04:39 PM
Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
2015 4Runner 4.0L; TGMO 5k miles
by OCDoiler. 06/19/19 04:17 PM
DesertTech, Jamie_E_M, Tambo, Robw, taschnewitz
68438 Registered Users
76 registered members (Bailes1992, Aredeeem, Astro_Guy, bbhero, BigCahuna, AZjeff, 7 invisible), 984 guests, and 23 spiders.
Topics290,689
Posts4,991,025
Members68,438
Most Online2,967
Mar 10th, 2019
Muffler pipe/flange: is it repairable ? #5108625
05/18/19 04:54 PM
05/18/19 04:54 PM
Canada
ST2008 Offline OP
ST2008  Offline OP
Canada
Hi guys
I just changed the muffler from my beater (see my My initial thread). It took me almost 5 hrs for the job. Because the idiot who installed the exhaust system had spot welded the nuts to the flange.
https://www.bobistheoilguy.com/foru...ion-for-exhaust-bolts-with-spring#UNREAD
As for the old Muffler, the structure is still very solid. It seems the muffler is made of all SS, but I have no idea what type of SS is. The only problem is the flange and the pipe were ruptured. (pictures)
I don't have welding machine. But do you think, it's repairable?
[Linked Image]
[Linked Image]
[img]https://i.imgur.com/TzQb584.jpg?1[/img]
[img]https://i.imgur.com/nOF5VGB.jpg?1[/img]
I bought a cheap aftermarket muffler as replacement. I'm pretty sure I need to change it two or three years later. If I could repair the old one with a fraction of price, that will be great.
thx
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108638
05/18/19 05:07 PM
05/18/19 05:07 PM
Newport News, VA
sdowney717 Offline
sdowney717  Offline
Newport News, VA
Sure, a muffler shop can and does weld together all sorts of pipe arrangements, some that should not be welded but bolted, they tend to do that. Made for a lot more work when I had to replace a catalytic converter with attached pipe as they had removed the bolted junction and welded up some kind of contraption.
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108639
05/18/19 05:08 PM
05/18/19 05:08 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Anything is repairable. That repair looks rather straightforward. However, the pipe looks rusty.
Many automotive exhaust systems are 409 stainless. Which is just barely good enough to hold up on salted roads.
I have a TIG welder in my shop and I use 308 rod on just about every "under the car" exhaust system. Sure, it's a mismatch in materials and not ideal, but it's very corrosion resistant. Using such rod on 409, 304 or aluminized pipe works well. As the weld is very corrosion resistant.
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108650
05/18/19 05:24 PM
05/18/19 05:24 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
You can check what you have with a magnet. 409 ss is magnetic; 300-series stainless is not.
Re: Muffler pipe/flange: is it repairable ? [Re: Cujet] #5108653
05/18/19 05:25 PM
05/18/19 05:25 PM
Canada
ST2008 Offline OP
ST2008  Offline OP
Canada
Thx for the inputs.
The front pipe of the muffler is indeed look rusted. But the tail pipe and the muffler itself are almost spotless. I also hit the muffler with a hammer to find any weak spot and I found nothing. The muffler seems to be an oem. The only thing I regret was I didn't put any alignement mark on the flange and on the pipe while I was removing the old muffler. So If I decide to repair the muffler, I need to put it back to my beater in order to find out the exact location of the flange and the pipe.
Re: Muffler pipe/flange: is it repairable ? [Re: Kestas] #5108664
05/18/19 05:38 PM
05/18/19 05:38 PM
Canada
ST2008 Offline OP
ST2008  Offline OP
Canada
thx for the tip
Something bizarre. The front pipe and the muffler are magnetic. But the tail pipe and the flange are not.
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108706
05/18/19 07:05 PM
05/18/19 07:05 PM
ME
eljefino Offline
eljefino  Offline
ME
Yes, there's a hinged split flange that will take a couple bolts and will then pull it towards a similarly shaped bell mouthed doodad on your other pipe. Put a sintered iron gasket in there.
The alternative is to cut that bell off and use a slip fit adapter and clamp. If it's a true beater you won't care that it's no longer a factory set up.
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108846
05/18/19 09:15 PM
05/18/19 09:15 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Look here, they have all sorts of stuff you can put together. You can cut a couple of slits then use a band clamp on them then tack them, clamp or weld them.
https://www.bearriverconverters.store/
Re: Muffler pipe/flange: is it repairable ? [Re: eljefino] #5108908
05/18/19 10:48 PM
05/18/19 10:48 PM
Green Bay, Wisconsin
DejaVue Offline
DejaVue  Offline
You beat me to it.
A band clamp that wraps around and is tightened down with two bolts also works. It costs a bit more than a coupler but is more removable.
For extended areas, that accordion-style pipe in fixit kits can last a long time. The main drawback is the exhaust needs to be supported in the other areas since the flexy pipe area won't have the rididness of solid pipe.
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5108957
05/19/19 12:13 AM
05/19/19 12:13 AM
NY
joegreen Offline
joegreen  Offline
NY
It's probably 409 stainless. Cujet says it looks Rusty but he is from Florida so everything looks Rusty to Southern folk. The pipe looks in great shape except for the end. I would go to the auto parts store and look at the exhaust section for ideas
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Muffler pipe/flange: is it repairable ? [Re: ST2008] #5109054
05/19/19 07:10 AM
05/19/19 07:10 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
On my Civic the nuts are welded to the flange from the factory.
Bolts come out, nuts stay on flange.
But yeah that is repairable:
https://fxexhaust.com/pr/honda.html
[Linked Image]
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
