Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
116 registered members (53' Stude, 28oz, 2015_PSD, 2012AccentSE, 1978elcamino, 12 invisible), 2,187 guests, and 31 spiders.
Topics289,301
Posts4,966,545
Members68,181
Most Online2,967
Mar 10th, 2019
Oil in the toolbox #5107687
05/17/19 12:58 PM
05/17/19 12:58 PM
USA
Floyd1 Offline OP
Floyd1  Offline OP
USA
Hello folks:
I now have a few trucks which have toolboxes on them. I usually keep a quart or two of oil in the toolbox just to have in case I ever need to add any or help someone out etc.
Where I live will begin to see temps in the 90’s everyday, so I’m sure the inside of the metal toolbox on the bed will easily reach over 100+F inside the toolbox while the truck is in the sun.
Will this lower the quality of the oil any? I know oils see temps much higher than this in the motor, but it would be flowing around, not sitting still in a plastic container.
Overall, I guess I’m asking if the constant fluctuation of temps, 50-60’s nights and 90+ days, will hurt the oil while it’s just sitting in the toolbox.
Am I overthinking? Is it really any different than a parked car with oil in the pan? The only difference being the oil is in a plastic bottle?
Thanks in advance
Re: Oil in the toolbox [Re: Floyd1] #5107689
05/17/19 01:05 PM
05/17/19 01:05 PM
Massachusetts
AuthorEditor Offline
Massachusetts
I almost never have less than a couple of quarts of oil in the trunk of my car, and that gets pretty hot on a summer day. I'm pretty sure that oil will be just fine as long as you use it up once in awhile. Make sure it is tightly capped.
Re: Oil in the toolbox [Re: Floyd1] #5107706
05/17/19 01:21 PM
05/17/19 01:21 PM
Cincinnati
Chris Meutsch Online content
Chris Meutsch  Online Content
Cincinnati
[quote=Floyd1]Hello folks:
Am I overthinking? YES Is it really any different than a parked car with oil in the pan? NO The only difference being the oil is in a plastic bottle? YES, PUT IT IN A ZIPLOC BAG.
[/quote
2005 Honda CR-V EX, 271k
Re: Oil in the toolbox [Re: Floyd1] #5107731
05/17/19 01:53 PM
05/17/19 01:53 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
That range of temperatures over any reasonable period is no issue but I would suggest you always use that oil for your next change. It's an easy enough thing to do and that way it won't sit there "forever". If nothing else, the container will stay in better shape.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Oil in the toolbox [Re: Floyd1] #5107732
05/17/19 01:55 PM
05/17/19 01:55 PM
pa
FT92 Offline
FT92  Offline
pa
only problem I can see is the bottle leaking due to expansion in the heat , otherwise all should be good
Re: Oil in the toolbox [Re: Floyd1] #5107755
05/17/19 02:29 PM
05/17/19 02:29 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I've got bottles of oil in an aluminum diamondplate TSC bed box that have been in there 20+ years. They have lasted just fine.
Re: Oil in the toolbox [Re: Floyd1] #5107764
05/17/19 02:45 PM
05/17/19 02:45 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Originally Posted by Floyd1
Am I overthinking?
Yes. You're going to fit right in here.
Re: Oil in the toolbox [Re: Floyd1] #5107808
05/17/19 03:35 PM
05/17/19 03:35 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
As said, I would put them in plastic bags just in case (although the plastic bags would probably deteriorate before the bottles), and would rotate the oil in the box on the next oil changes if not used in a year or so.
That said, I carry a qt of oil under my hood by the firewall in my F150 for top off's (it uses 1 qt every 1500 miles or so). I have been refilling the same bottle for 3 years now and the bottle is still fine. It does feel a little softer than same bottles that are sitting on the shelf in my garage, but no leaking or cracking.
'18 Santa Fe:Delo XLE 10W-30, OEM, 3k
'12 xB: QSUD 5W-20, CQ Blue, 5k
'07 Vue: Synpower 5w-30, Ecogard Syn, OLM
'02 F150: Magnatec 5W-20, Bosch D+, 1yr
'94 VT1100: Peak 15W-40, Bosch D+, 1yr
Re: Oil in the toolbox [Re: Floyd1] #5107818
05/17/19 03:45 PM
05/17/19 03:45 PM
California
DGXR Online content
DGXR  Online Content
California
You're fine, just use up this oil at the next service and put some fresh bottles back in the tool box. If you do this rotation at every service it will never go bad.
I keep a jug of oil in my dirt bike gear bag and use that first when service is due. Replace the jug as needed. All good.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Oil in the toolbox [Re: Floyd1] #5107829
05/17/19 03:50 PM
05/17/19 03:50 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
I once left a small metal can of touchup paint on top of the dash in the Florida sun. The lid blew of and made a big mess on the dash and carpet. Don't think oil is that volatile.
Re: Oil in the toolbox [Re: Floyd1] #5107837
05/17/19 03:55 PM
05/17/19 03:55 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
your worried about 140F or so vs 230F+ on a running engine?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Oil in the toolbox [Re: Bottom_Feeder] #5107854
05/17/19 04:29 PM
05/17/19 04:29 PM
US
JLTD Offline
JLTD  Offline
US
Am I overthinking?
thumbsup Just use the oil for your next change and rotate stock. . .
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 147k, SS5w30/Amsoil
His: 2015 4Runner 53k, OE5w30/Wix
Re: Oil in the toolbox [Re: atikovi] #5107943
05/17/19 07:01 PM
05/17/19 07:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Paint often contains thinners and solvents that will boil at relatively low temperatures.
Re: Oil in the toolbox [Re: atikovi] #5107985
05/17/19 08:08 PM
05/17/19 08:08 PM
ecotourist Offline
ecotourist  Offline
I used to carry gas line antifreeze (methyl hydrate) in a "single dose" plastic container in my glove compartment. I didn't think to take it out in the summer and later noticed that the originally flat bottom of the container was bulging. It didn't leak but there must have been some increased pressure.
Re: Oil in the toolbox [Re: Floyd1] #5108004
05/17/19 08:25 PM
05/17/19 08:25 PM
USA
Floyd1 Offline OP
Floyd1  Offline OP
USA
Thanks folks. This site makes me second guess everything, but that’s what keeps me coming back, am I right?
