Originally Posted by JHZR2
Originally Posted by Donald
While the Milwaukee M18 Fuel Hi Torque might not have as much nut busting power as the most powerful 1/2" pneumatic impact wrench (and certainly not as much as a 3/4") it will probably remove all the bolts and nuts the OP is likely to come across.
I think shops use the pneumatic impact wrenches as they are more rugged, can be dropped, dragged by the hose and do not need recharging. More balanced and lighter.
But for the most part you need to bring the work to the air supply. With a cordless impact wrench, you can bring the wrench to the work. And while I have plenty of air hose, I would just assume not drag the air hose through mud or similar to remove a nut or bolt on a trailer.
Obviously the best solution is to have both.
Dunno...
Tried removing these lugs off of chromed wheels. The car has always lived in CA until I brought it here, and never has seen snow. Some rain since being here though...
Lugs were affixed for around 7 years.
My M18 impact couldn't remove these bolts, a long breaker bar could.
Those may have also been installed with an air impact 7 years ago. As we all know some places just zap them on with the air guns and stop when it starts hammering. Could have been ridiculously tight to begin with.
