Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
35 registered members (BlueOvalFitter, Bighorn2500, chemman, bagyoau, 8 invisible), 632 guests, and 18 spiders.
Topics290,258
Posts4,987,222
Members68,412
Most Online2,967
Mar 10th, 2019
Does Liqui Moly Motor Oil Saver break down RTV Sealant? #5107168
05/16/19 08:03 PM
05/16/19 08:03 PM
Singapore
Calikura Offline OP
Calikura  Offline OP
Singapore
As above. I'm going to be using a smaller-than-recommended dose (maybe 8-12oz or so in 4qts oil) to see if a tiny rear main seep will be gone by my next oil change. However I'm also aware that there are a bunch of parts of my engine, such as the oil pan, that don't have a gasket - they came with just a bead of RTV from the factory. I also have a little at the corners of my valve cover and timing cover.
(To clarify: I'm using the product for the rear main, not the RTV. The RTV isn't leaking)
I've not used ester-based oils in this engine before, and maybe I'm a little paranoid, but would the Motor Oil Saver be expected to have any destructive effect on RTV sealant, especialy if left in the engine (albeit in small dose) for nearly an entire OCI?
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5107175
05/16/19 08:16 PM
05/16/19 08:16 PM
MN
oil_film_movies Offline
MN
RTV is silicone rubber, not affected. There was an earlier discussion of this same subject, and the consensus was there is no swelling or plasticizer effect on the silicone rubber seals.
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5107188
05/16/19 08:40 PM
05/16/19 08:40 PM
Bushnell Optics Store KC KS
Marco620 Offline
Marco620  Offline
MOS fixed my Hyundai Accent oil leak RMS. Added full can and filled with PP 5w30. Next oci I did the same but with 1/3 can and after that no weeps of oil. Call 888 moly oil and ask tech support. They should have you fixed up.
15' Civic 1.8 i-vtec 246,000 mi Redline oil 0w20 & M1 0w30 3:1/BP transmax cvt fluid & Archoil9100
Say no @ redheads,drugs,and gummi beers
Son of a Navy Corpsman. Support vets!
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: oil_film_movies] #5107270
05/16/19 10:28 PM
05/16/19 10:28 PM
Maryland USA
rubberchicken Offline
Maryland USA
There was a tech bulletin back in the early 2000's that many GM differentials had RTV that was attacked by certain gear oils, even though the oil met the GM spec. The fix was to repair with a different brand of RTV. So his concern about RTV seems to be grounded in real-world problems: if I can find the tech notice I will post it. That said, I have NO idea on the Liqui Moly product in question.
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Marco620] #5107317
05/17/19 12:29 AM
05/17/19 12:29 AM
Singapore
Calikura Offline OP
Calikura  Offline OP
Singapore
Great to hear! Am I mistaken or do Hyundai oil pans also not come with rubber gaskets but sealed from the factory with just their "Ultra Blue" RTV?
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5108139
05/17/19 11:38 PM
05/17/19 11:38 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
The silicones from RTV sealers can leach out into PCMO's so if you do a UOA and see elevated silicon levels there is no need for alarm and the minor leaching does no harm to anything else.
Science is about objective reality, not consensus.
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5119602
05/29/19 07:21 PM
05/29/19 07:21 PM
Wilmington, NC
harry j Offline
harry j  Offline
Wilmington, NC
no problem, RTV laughs at that additive.
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5119879
05/30/19 01:43 AM
05/30/19 01:43 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Can't speak for all models but my 09 was factory RTV sealed. You might drop an email to the stop leak mfg and ask them that question but I'd be surprised to learn it did. Seems to me that they'd be severely limiting their products suitability if it had a destructive solvent like effect on silicone based RTV's.
That would be my guess too...
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5121907
06/01/19 06:14 AM
06/01/19 06:14 AM
Singapore
Calikura Offline OP
Calikura  Offline OP
Singapore
Thanks for all the reassuring replies. I wrote to LM and they also assured it would not be a problem. Went ahead and put it in my engine and it has been without problems so far. Hope it works its magic for the seal!
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5124364
06/03/19 05:51 PM
06/03/19 05:51 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
I hope it works too cuzz rear mains aren't easy nor cheap to replace as I'm sure you know by now.
Re: Does Liqui Moly Motor Oil Saver break down RTV Sealant? [Re: Calikura] #5124860
06/04/19 07:58 AM
06/04/19 07:58 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Look at the ingredients and compare them to the products in this chart. Do a search through the list for "ester", you will notice almost all ester related products are not compatible. I have pulled many a pan that RTV was used on OE and pulled of a soggy mess that used to be RTV.
I am not saying all RTV will be effected the same was as I am sure there are different formulations but how would you know.
RTV
