Found a Good deal!!!
by GuinnessGuy - 12/15/19 11:28 PM
Serpentine Belt Change
by Propflux01 - 12/15/19 08:59 PM
QS HM 10W-40
by kstanf150 - 12/15/19 08:29 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
Selling my dump trailer
by Sunnyinhollister - 12/15/19 11:43 AM
Motorcraft 5W-20 canada
by xXF150Xx - 12/15/19 11:40 AM
Brake caliper pins
by Donald - 12/15/19 11:14 AM
bjonga, theman5142, 750IX, Tzam, tjl5709
70138 Registered Users
53 registered members (BLND1, BlakeB, adams355, 2009Caraman, 5 invisible), 1,186 guests, and 19 spiders.
Topics298,851
Posts5,142,620
Members70,138
Most Online3,589
Nov 2nd, 2019
Cooling fan staying on after shut-off, Honda Pilot #5094009 05/02/19 03:51 PM
Chris Meutsch Offline OP
2008 Honda Pilot that my ex drives, I bought it back in 2010. She mentioned for the past few days, one of the fans under the hood runs after she shuts it off. I'm thinking it could be a relay going bad considering it never did this before? I do need to check the coolant level just as a precaution. She said the temp gauge didn't appear to go any higher than normal. Car has been BITOG-maintained.
Thanks in advance.
2005 Honda CR-V EX, 278k
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5094033 05/02/19 04:15 PM
Char Baby Offline
Yes, check the coolant level.
Also, it is not abnormal for a fan to run after the engine is shut off and say so in most owner's manuals and repair manuals.
But, since you've owned the vehicle and the fan has never stayed on after the engine is turned off(still being cool/cold outside) then, I think you're on to something with the relay or sensor issue.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5094039 05/02/19 04:29 PM
M
mclasser Offline
M
I took a quick look at the Pilot forums and this issue is commonly due to low coolant or a bad relay.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5094052 05/02/19 04:42 PM
A
ad244 Offline
A
Swap the fan relay
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5094108 05/02/19 05:40 PM
I
Ihatetochangeoil Offline
I
OK. I paid extra for an aftermarket PCM that runs the fans for 5 minutes after engine shutdown if the temperature is over 185. Just curious, what is "BITOG" maintained? Thanks.
Whatever
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Ihatetochangeoil] #5094118 05/02/19 05:48 PM
dbias Offline
Id say that means he "doesnt hate to change oil"
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Ihatetochangeoil] #5094141 05/02/19 06:14 PM
JohnnyJohnson Online Content
Online Content
LOL it should have read EX wife maintained.
2004 Corolla 137480
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76862
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Ihatetochangeoil] #5094683 05/03/19 09:26 AM
It's code for "we're all neurotic about maintaining our vehicles and treat them better than our own bodies."
I'm going to get coolant today and look at it tomorrow morning. I've smelled "faint" coolant smell for a couple months now but can't see leaks or hear sizzling.
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5094712 05/03/19 09:52 AM
T
Trav Offline
T
Either that or some are so cheap they run the cheapest swill oil and spend money on UOA's instead of good oil trying to get the last mile out of the oil. To supplement my cheap oil I got an expensive ceramic snake oil additive and a Fram Ultra filter to prevent my engine from wearing out but now I am PO'd because the timing belt broke and bent all the valves. There are 2 sides to that coin.
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5096007 05/04/19 08:50 PM
UPDATE: It was low on coolant. Added 3/4 of a gallon of Peak Global Lifetime, burped it properly, and everything is back to normal.
Now to figure out where it's going. It's not mixing with the oil, it's not "sizzling" indicating a leak in the head gasket, it's not dripping on the ground anywhere, no wet spots. Interesting.
I guess the good news is I won't be paying for any repairs down the line!
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5096052 05/04/19 09:25 PM
I
I
Chris, I've never seen under the hood of a 2008 Honda Pilot, but I'll share what's happened to my daughter's car (she's still at home, so I BITOG maintain MY car that SHE drives). It's got a GM 3800 (notorious for intake leaks) in it. I noticed that the coolant level in the overflow reservoir goes down SLOWLY (takes a couple months) but it does drop. No overheating, no spots on driveway, no coolant in oil (UOA) so I'm NOT guessing.
Got to looking around the engine compartment closely, coolant stains barely visible on top of the timing chain cover. Oring on plastic coolant elbow leaking ever so slightly, the coolant either gets cooked off by engine heat or evaporates due to air movement at cruise, NEVER any coolant on the ground. Methinks you've got something similar, 3 quarts of coolant doesn't just disappear. I have also used a 1000 lumen black light flashlight to find coolant leaks in a dark garage. https://www.globaltestsupply.com/pr...5kNp9h5yjYr4STHUGP8vR9aIRaRoC40sQAvD_BwE
Whatever
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Ihatetochangeoil] #5101421 05/10/19 08:54 AM
Thanks!
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Ihatetochangeoil] #5101477 05/10/19 09:47 AM
W
WyrTwister Offline
W
The factory plastic coolant elbows are a classic issue with the GM 3.8l . Replace them with after market metal parts .
If the plastic ones break , I will bet it will not take long to pump the system dry , at high way speed .
Wyr
God bless
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5107053 05/16/19 03:54 PM
Turns out there's a small leak at the bottom seam of the radiator that only leaks under pressure.
$631 to fix, or $8 for GM coolant tabs to see how those go.
Tabs for the win!
Re: Cooling fan staying on after shut-off, Honda Pilot [Re: Chris Meutsch] #5107090 05/16/19 04:50 PM
The Critic Offline
Tabs for the win!
Replace the radiator. Coolant leaks are not something to mess around with, especially on the radiator.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
