Nissan Part Number E2901-62U01- Now obsolete in the USA.
I'm hoarding about 4 liters, but I have a small leak from the active pump and will need to do some surgery soon that involves draining the system. So...need a suitable replacement and looking for some suggestions.
Note that the sample tested was produced in 2011, and has been sitting in a steel(?) can for 7+ years, which is my suspicion on the tin (leeched out of the container). Blackstone indicated that tin may have been long ago used as an additive, but I've not heard of this, nor do I understand why it would be a designed additive.
FP seems low to me, but maybe it's because I only sent them a 3oz sample instead of 4oz?
Offhand, Toyota WS ATF looks pretty close on the basic numbers, but the subject fluid is more akin to a hydraulic fluid based on research so far.
Here's the can it comes in along with some properties.
