Which Synthetic Oil Do You Use, And Why?
by BlueOvalFitter. 07/18/19 10:50 PM
do laptop batteries really go bad or
by WhyMe. 07/18/19 10:32 PM
2016-2017 Chevy Equinox reliability
by gregk24. 07/18/19 10:12 PM
Mann HU816 x
by IllinoisSparky. 07/18/19 09:41 PM
Seafood Combo
by vavavroom. 07/18/19 09:37 PM
‘13 Silverado 1500 Extended Cab
by parshisa. 07/18/19 09:35 PM
Where to have a watch serviced?
by E150GT. 07/18/19 08:32 PM
Stubborn diff fill plug
by HoosierJeeper. 07/18/19 08:21 PM
Big score on auto parts clearance AAP
by Marco620. 07/18/19 08:05 PM
Would this cause my jeep to stall?
by MileHigh18. 07/18/19 08:00 PM
Looking for Highlander '06,'07, '09
by Gebo. 07/18/19 06:39 PM
'03 F150 Parking Brake Adjustment
by benjamming. 07/18/19 06:17 PM
Do You Still Change Your Oil at 3K?
by Gebo. 07/18/19 05:33 PM
Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
30 years clean & sober today.
by Papa Bear. 07/18/19 02:03 PM
suuru, Hollicrev, Richb55, Shaz, Grousebeater
68702 Registered Users
65 registered members (10WSmuckers, 4WD, alchargo, 01rangerxl, 2015_PSD, AZjeff, 10 invisible), 1,274 guests, and 26 spiders.
Topics292,057
Posts5,016,041
Members68,702
Most Online2,967
Mar 10th, 2019
Page 1 of 8 1 2 8
Why hasn't someone made a more efficient filter? #5106820
05/16/19 11:36 AM
05/16/19 11:36 AM
Oakville, Ontario
Patman Offline OP
Global Moderator
Patman  Offline OP
Global Moderator
Oakville, Ontario
I'm curious as to why no manufacturers out there have made an oil filter than is even more efficient than what we currently have, let's just say something that's 99% efficient down to 10 or 15 microns instead of the current best which seems to be around 99% at 20 microns. Surely the technology must exist.
2018 Corvette, 13k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 151k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,116k, GC 0w40 & Fram Ultra
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106823
05/16/19 11:40 AM
05/16/19 11:40 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Is more filtration really needed? Do engines fail because existing filters don't filter enough? Will more efficient filters restrict flow too much?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106824
05/16/19 11:40 AM
05/16/19 11:40 AM
Central Wisconsin
dwendt44 Online content
dwendt44  Online Content
Central Wisconsin
The cost would be through the roof. Plus the larger media would require a larger
'can' to meet oil flow requirements. Many engines don't have room for a giant filter can.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106825
05/16/19 11:42 AM
05/16/19 11:42 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
What is the need ?
2015 F150 2.7
2018 F350 6.2
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106827
05/16/19 11:43 AM
05/16/19 11:43 AM
Ohio
hallstevenson Offline
Ohio
Because it's truly not necessary ? What's the difference between 10 microns and 20 microns ? And I'm only asking these two questions: 1) At what level will the filter trap additives ? 2) Will flow be (too) restricted ?
Cost will be a factor too. It might cost substantially more while there's no need for it.
Re: Why hasn't someone made a more efficient filter? [Re: CT8] #5106845
05/16/19 12:03 PM
05/16/19 12:03 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Originally Posted by CT8
What is the need ?
Maybe this.
2004 Corolla 134004
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75175
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106847
05/16/19 12:05 PM
05/16/19 12:05 PM
st louis, mo
brages Offline
brages  Offline
st louis, mo
The "toilet paper" bypass filters claim to remove extremely small particles at a low flow rate... https://www.frantzfilters.com/
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106851
05/16/19 12:08 PM
05/16/19 12:08 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I thought that was what By-pass filters were made for.
There is a trade-off between particle filtering capabilities and cost. smile
"Science is a body of knowledge, a 'recipe', as it were, for reality. The totality of science is a collection of hard-earned nuggets, using math as a language of expression." Chip Cohen
Re: Why hasn't someone made a more efficient filter? [Re: CT8] #5106852
05/16/19 12:08 PM
05/16/19 12:08 PM
Oakville, Ontario
Patman Offline OP
Global Moderator
Patman  Offline OP
Global Moderator
Oakville, Ontario
Considering how well the Fram Ultra flows in it's current form, couldn't they just tweak that media a little bit in order to filter even better, while not compromising flow by much?
What is the need ?
I'm mainly just curious as to why they don't exist, from a technical standpoint. But I'm also wondering why someone wouldn't do this and market the heck out of it in order to grab a bigger slice of the DYI oil change market. Performance enthusiasts would snap them up, even though most of them probably won't see the long term benefits of finer filtration.
I've always believed that the more efficient the better, even if it's overkill for most people since they trade their cars in long before the engine wears out.
Re: Why hasn't someone made a more efficient filter? [Re: MolaKule] #5106853
05/16/19 12:10 PM
05/16/19 12:10 PM
Oakville, Ontario
Patman Offline OP
Global Moderator
Patman  Offline OP
Global Moderator
Oakville, Ontario
True, but even if they charged $15 or $20 (as opposed to the $10 for the Ultra) they could still be popular.
As far as bypass filtration goes, I think the complexity of it scares a lot of people away. Having a simple spin on filter that is super efficient would be more user friendly.
Re: Why hasn't someone made a more efficient filter? [Re: dwendt44] #5106859
05/16/19 12:17 PM
05/16/19 12:17 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
My 2¢
This. There's simply no room and it's not needed. Insufficient filtration is no longer a failure point.
435i
Re: Why hasn't someone made a more efficient filter? [Re: BMWTurboDzl] #5106878
05/16/19 12:52 PM
05/16/19 12:52 PM
Oakville, Ontario
Patman Offline OP
Global Moderator
Patman  Offline OP
Global Moderator
Oakville, Ontario
But maybe we need to think of it in terms of not the failure point, but keeping the engine running perfectly for the entire time you own the car. If finer filtration means the engine stays "as good as new" for a longer period, isn't that worth it? In other words, maybe that engine with 100k on it now doesn't burn any oil, instead of using a quart every 5k if it was slightly worn. Maybe it's making 98% of it's original horsepower instead of being down to 90%. Maybe it still gets the same MPG as new, instead of it dropping by a few %.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106884
05/16/19 12:57 PM
05/16/19 12:57 PM
New England
Virtus_Probi Offline
New England
Wasn't this the idea behind the Microgreen filters?
Integrated bypass to filter out the tiny particles while maintaining full flow in one modestly sized package?
I guess the question is if they actually did what they said...I know there was some controversy about the end product possibly being a total [censored] of the original intent and the idea man behind it supposedly being forced out of the company.
2014 Forester XT, 100000 miles
Last Change;
M1 10W30 HM SN+
Tokyo Roki 15208AA170 filter
Re: Why hasn't someone made a more efficient filter? [Re: Virtus_Probi] #5106910
05/16/19 01:22 PM
05/16/19 01:22 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Whatever happened to those … any users still here ?
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5106927
05/16/19 01:44 PM
05/16/19 01:44 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
1st: oil filter is not the limiting factor of vehicle life, the current cheap oil filter is good enough before other things kill the car (rust, transmission, head gasket, turbo, accident, exterior, fashion, etc)
2nd: we already have toilet paper bypass filter, most people decided it is not worth the trouble and cost.
3rd: you still need to change the oil and add additives, so why bother. You also have to add oil to deal with burning, etc.
The OEM can make the filter 2x or 3x as big, but they still get changed when it is not filled up, so they shrink it to make it cheaper to make, cheaper to ship, cheaper to stock, and cheaper to dispose.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Page 1 of 8 1 2 8
