ELECTRICAL CONTROL UNIT (MOPAR ORANGE) (P4120505)
by BeerCan - 08/18/19 02:55 PM
edelbrock ch4b intake
by BeerCan - 08/18/19 02:48 PM
edelbrock carb
by BeerCan - 08/18/19 02:43 PM
Will 2015 5.0 Coyote Notice the Difference?
by BISCUT - 08/18/19 02:37 PM
Fleetguard Fuel Filter FF5301 (4)
by Bighorn2500 - 08/18/19 02:04 PM
AC Compressor
by borgward - 08/18/19 01:40 PM
MK7.5 GTi- Oil and Injector cleaner
by Striker - 08/18/19 12:17 PM
Cheap Hack for Cheap Sunglasses
by RayCJ - 08/18/19 10:55 AM
Detailed Engine using Infinity Wax Rubber Wax
by buster - 08/18/19 10:52 AM
Nissan 15208 9E01A oil filter
by passgas55 - 08/18/19 10:35 AM
by buster - 08/18/19 10:01 AM
Bad oil pressure sensor?
by HoosierJeeper - 08/18/19 10:00 AM
So many oil changes, so little time....
by cwhard - 08/18/19 09:10 AM
What oil did iroc use?
by Red91 - 08/18/19 09:09 AM
Differential cover "load bolts"?
by kehyler - 08/18/19 07:39 AM
Havoline Box
by JLTD - 08/18/19 07:17 AM
Best Oil Change Ramps ??
by billt460 - 08/18/19 05:20 AM
HardCoreHawkFan, JustChuck, AGs61Vette, KsEXL, madscientist7
68991 Registered Users
91 registered members (1foxracing, 53' Stude, AHernandez, 2KBMW, Al, 11 invisible), 2,365 guests, and 23 spiders.
Topics293,465
Posts5,040,769
Members68,991
Most Online3,532
Jul 30th, 2019
Page 2 of 3 1 2 3
Re: Filtering and reusing oil? [Re: JC1] #5106629 05/16/19 08:09 AM
4WD Offline
The Tribol Leaders have spoken on this matter.
Head to the mainland for new oil and coffee.
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106644 05/16/19 08:20 AM
L
Langanobob Offline
L
He only has 500 miles on the oil but he rides hard. I think what he’s asking is there any benefit to draining and straining the oil through a coffee filter every few hundred miles in between the regularly scheduled oil changes.
I don’t see any harm to it. You could try it once and see what the coffee filter picks up. If there’s anything visible in it then yes, it might be worthwhile.
Re: Filtering and reusing oil? [Re: Langanobob] #5106647 05/16/19 08:23 AM
B
Bonz Offline
B
I agree with the above post, the oil isn’t outside the specified change interval, just an in between and reuse. Actually would be curious what shows up when he does that.
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106656 05/16/19 08:29 AM
V
Virtus_Probi Offline
V
I suppose you could use some kind of toilet paper filter arrangement like many in-vehicle bypass filters use if you are willing to wait for the oil to soak through...many users of bypass filters will run their oil for tens of thousands of miles.
I imagine a significant portion of the oil from a small sump would end up staying in the TP, though....might not be worth it.
I doubt a coffee filter will do jack...
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106678 05/16/19 08:48 AM
Cujet Offline
The issue with fine filtration is that oil shear, additive depletion and liquid blowby contaminates are not addressed.
Over enough time, you could end up with an oil that is diluted by as much as 25% gasoline by products, a few grades below spec and acidic.
The oil change is the only way to ensure clean, serviceable oil.
HOWEVER, ongoing submicronic filtration has some significant advantages, as the oil never accumulates larger particulates. Such particulates are known to contribute to timing chain and piston ring wear.
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106717 05/16/19 09:29 AM
N
Nikolas Offline
N
$10000 bike - check
$20 oil change? nah, too spendy!
Re: Filtering and reusing oil? [Re: Langanobob] #5106757 05/16/19 10:00 AM
blupupher Offline
This is how I read it also. Not re-using 2000 mile oil, but draining and coffee filtering the oil every 500 miles then putting it back in.
From what I can find, coffee filters are ~20 microns, so a decent particle size will be caught. Is it worth the hassle of doing it and would there be any benefit?
Don't know anything about this engine, but from a quick google search, this thing has both oil filters and oil screens, so the engine is already filtering the oil.
Why go through the hassle of draining, filtering and pouring back in (as well as having to use some new oil for top off)?
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106759 05/16/19 10:02 AM
J
JMJNet Offline
J
The challenge is how to keep the oil from contaminant during the process of draining, filtering and putting it back into the engine.
A clean to the eyes container can or coffee filter, may have bigger contaminant than that of the one there.
  • 2017 Toyota Sienna
Re: Filtering and reusing oil? [Re: Langanobob] #5106785 05/16/19 10:44 AM
Z
zzyzzx Offline
Z
I'd like to see those used coffee filter pictures posted here. Who knows what you are going to find unless you try it.
Re: Filtering and reusing oil? [Re: zzyzzx] #5106902 05/16/19 01:17 PM
blupupher Offline
I have done this before.
I changed the oil in my Scion @ 5000 miles for warranty. I was using synthetic and I am sure there was nothing wrong with the oil, so when I drained it, I drained it into a clean 5 qt jug. Used the oil for top off oil in my truck and brother in laws truck. Before using it, I filtered it through a coffee filter (poured it from the 5 qt jug into a 1 qt bottle, used the filter to make sure it was clean).
The coffee filter had nothing in it that I could see.
If this was a moped or other bike with no filter, I would imagine there would be some stuff in it.
Re: Filtering and reusing oil? [Re: Nikolas] #5106933 05/16/19 01:49 PM
A
aquariuscsm Offline
A
Originally Posted by Nikolas
$10000 bike - check
Indeed!
Op,be nice to your bike. Just change the oil.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Filtering and reusing oil? [Re: MDifabrizio] #5106937 05/16/19 01:54 PM
P
PandaBear Offline
P
Not motorcycle but I've tried filtering engine oil through coffee filter (10w30), it won't go through fast enough if you value your day for more than $1/hr topping it off. If you want to, use a larger pores filter (i.e. cloth, paper towel) and then let your oil filter do the job cleaning out the small stuff. If you are concerned just use cheap new oil.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Filtering and reusing oil? [Re: Lubener] #5106941 05/16/19 02:06 PM
Malo83 Offline
Originally Posted by Lubener
Originally Posted by MDifabrizio
I have a husqvarna 701 with a motorex lc4 engine 2500 miles and I don’t baby it when I ride.
My question is can I dump the oil, drop the screens and filters then run the oil through a coffee filter and re install every few rides? Last oil change was @ 2000 miles.
I can't believe I am reading something so ridiculous like this.
crackmeup
Re: Filtering and reusing oil? [Re: MDifabrizio] #5107088 05/16/19 05:45 PM
Z
ZeeOSix Offline
Z
What's this engine have for an oil filter?
Re: Filtering and reusing oil? [Re: MDifabrizio] #5107398 05/17/19 06:46 AM
T
troop Offline
T
This ...... topic ........... keeps ... drawing ..... me .....back
Page 2 of 3 1 2 3
