Originally Posted by KneeGrinder
I use Delvac 1, 5W40 in my Chevy 6.6L only. Its my winter, mountain dirt road, fire wood cutting, hunting truck. Has a set of stud less Blizzak's for winter, Goodyear Mud's for the mountains. EFI Live Tune's.
Delvac 1 5W40 currant stock on the shelf is rated API service, CK-4, CJ-4, CI-4plus/ ACEA E9,E7.
It is also rated SM/SN but is not labeled on any of the containers, jugs, or pails. It has been rated SM/SN for years, they just don't seem to want to label it for some reason. Whatever that reason is? It does not make any sense! You can only find that SM/SN spec on the Delvac website.
I will go look for the $10.00 per jug discount for you. I got my rebate in 2/3 weeks, its separate from Mobil 1. So if you did a Mobil 1 rebate, you can do a Delvac rebate also.
https://www.mobil.com/en/mobil-delvac/products/promotions/40-off-mobildelvac
I helped friend do Delvac rebate already sir
Thanks for info also
