music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
102 registered members (55hambone, 2015_PSD, 4WD, aquariuscsm, 2010Civic, 11 invisible), 1,887 guests, and 43 spiders.
Topics306,218
Posts5,288,481
Members71,608
Cutting Fluid/Coolant For Lathe #5104058 05/13/19 09:20 AM
N
nightshift20192 Offline OP
N
I have been using a Rustlick water soluble cutting fluid for cutting operations on a small lathe. I've been thinking about going to a non-water cutting oil instead. The issues are rust and tool life. Part of the problem may be that the lathe gets used infrequently. Does anyone have any thoughts or recommendations? Thanks in advance.
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5104076 05/13/19 09:36 AM
W
WyrTwister Offline
W
Try to find a machinist list to ask . Also , look on youtube .
I am not a machinest , but enjoy watching that type of bideos .
Did not realize how long water based coolants have been used . Watched a video this weekend . A company in Canada , during WW! , making 8" howitzer projectiles .
They were using water based flood coolant .
Wyr
God bless
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5104083 05/13/19 09:46 AM
R
ragtoplvr Offline
R
for my hobby lathe I use Tap Magic thick, a very thin coat applied over surface before each cut. If you make a big mess you used too much.
Or I use blast of compressed air, I have a tube rigged up, it cools well.
Rod
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5104382 05/13/19 03:38 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
If used infrequently, don't use water-based coolant. For all the places I've used a lathe, mill, or band saw, we used it dry.
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5105456 05/14/19 07:18 PM
N
N
Thank-you all for your input. It is very much appreciated!
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5105480 05/14/19 08:13 PM
I
Imp4 Offline
I
This is a great question to ask at Practicalmachinist.com
Re: Cutting Fluid/Coolant For Lathe [Re: nightshift20192] #5134395 06/14/19 08:24 PM
M
Merek Offline
M
I'm a machinist, my dad has a machine shop and right now it seems like I've mostly been keeping the cnc lathe going. We order a coolant that comes in 5 gallon buckets from MSC called Astro-Cut, we've used the A & B but there are a lot of different ones, all of them you mix with water. We did have a 55 gallon drum from another shop that closed up that was a cutting oil that you mixed with water but the problem was that the water either evaporated out or burned off leaving the really thick oil behind. We also use tap magic for other applications and it works very well.
Sounds like you will be using this infrequently and I'm sure you would be fine with using a cutting oil.
