Most rear end fluid/gear oil and some transmission fluid are extremely strong smelling of what seems to me sulfur. Does this indicate anything as far as base oil goes? The ATF4 used in Chrysler products along with most gear oil smells like this. I know crude oil has much sulfur prior to refining, are they leaving some behind for these products or am I smelling something else? The only automotive smell more distinctive is carb dip from the past, yuck.
