Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
106 registered members (390pi, 2K2AcuraTL, 01VFR, 28oz, 928, 53' Stude, 6 invisible), 2,304 guests, and 21 spiders.
Topics301,613
Posts5,199,111
Members70,742
Page 4 of 8 1 3 4 5 8
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: Bonz] #5076417 04/16/19 05:43 AM
M
metroplex Offline
M
Originally Posted by Bonz
That oil is the recommended oil in the 2014+ BMW R1200RT, and used it flawlessly in the VStrom 1000 and ZRX1200. Clutch slippage with T6 5w40 is not par for the course with any bike or brand.
That's what everyone told me regarding T6 5W-40. As soon as I drained it and switched to a different oil, it no longer slipped. Keep in mind this was only during WOT shifting. M1 V-Twin 20W-50 and Castrol 10W-50 are fine with my wet clutches. This was during a time when the Ducati-recommended OEM Shell Advance 4T was not readily available in the US. Even the Ducati dealers didn't carry it.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5077139 04/16/19 06:45 PM
M
Merek Offline
M
Advance is now carrying Shell motorcycle oil but last I checked it's $12.99 qt. I'd love to try it in mine but I can find other motorcycle oil for less, even Mobil 1 is cheaper.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5077369 04/17/19 12:45 AM
K
Kamele0N Online Sick
Online Sick
K
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: Merek] #5077555 04/17/19 07:21 AM
T
troop Offline
T
Ships to store for free ...
https://www.walmart.com/ip/2CG62RFX...p;registryId=undefined&selected=true
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: Kamele0N] #5083701 04/23/19 11:07 AM
W
webfors Offline
W
Nice! Wish the viscosity was in the 15-16 range, but I'll take it if it doesn't shear like its' T6 sister.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5096536 05/05/19 12:11 PM
G
Goodkat Offline
G
Took the first ride if the season with the V Strom 1000 last night using this new T6 15w40 and so far so good. There was no clutch slippage, odd noises or anything thing else that could be bad to note. It ran smooth, shifted great and I think it might rev just a touch quicker. Big thumbs up so far!
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5104691 05/13/19 08:28 PM
B
BigJohn Offline
B
Finally... my local WallyWorld offered it.....
I purchased a gallon.
Tell you all.... the ultimate litmus on this oil is the KTM 950. This engine is the most finicky of any that I have every owned. The only oil it really loves is conventional, Rotella 15w40. So I will dump what is in the sump and add this "elixir oil" to see how she does..... If it is a negatory.... I will go back to conventional 15w40 with all the JASO ratings.
[Linked Image]
14 Ram 1500 EcoDiesel 4x4, T6 5w40
15 Mercedes ML250 BlueTec, PenEuro 5w30
16 Honda VFR1200x, T4/T6 Blend
14 BMW G650GS Sertao, T4/T6 Blend
10 Mahindra 2816 HST, T6 15w40
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: Truckedup] #5104730 05/13/19 09:40 PM
blupupher Offline
Interesting that everyone keeps saying that T4 and T6 are JASO MA rated, but they are not.
Rotella T4 and T6 labels state "Meets the performance requirements of: ... JASO MA/MA2".
"Meets requirements of" is not the same thing as JASO MA/MA2 licensed/certified.
[Linked Image]
Where on the bottle is the MA rating square with their certification number?
All JASO MA/MA2 certified oils will have that, just like this bottle of Honda oil:
[Linked Image]
Where is any Rotella on the JASO MA/MA2 licensing list?
While I agree Rotella (and Delo, and most other HDEO) work great in most wet clutch bikes and most likely meet or exceed the MA/MA2 specs, none of them are JASO MA/MA2 licensed.
I am running Peak Syn-Blend 15w-40 HDEO in my bike right now, and it says nothing on the label about JASO MA at all. I have no issue using it, but I also know it is not designed for it.
Some "motorcycle" oils from Mobil, Castrol and Valvoline also are not MA licensed oils. Again, check the list or look at the back of the bottle.
Originally Posted by Truckedup
I believe the JASO rating is up to the manufacturer...? I'm looking at a year old bottle of Mobil1 Vtwin with a outline of a Harley type bike on the front and JASO is nowhere to be found..
Nope. As you mentioned, the Mobil 1 V Twin is for Harley bikes, so no need for the JASO MA/MA2 certification. Probably works fine in wet clutches, but not certified for it.
and to be clear, I have nothing against using Rotella in a wet clutch bike, just the fact that everyone seems to be thinking that advertising wording on the label and website is the same thing as having the correct licensing/certifications. You have as much of a guarantee from Shell using T4, T5 or T6, since non of them are JASO MA/MA2 licensed.
Why they have this wording on T4 and T6, well, easy to see, it sells. Why is it not on T5, no idea.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5104745 05/13/19 10:06 PM
Snagglefoot Online Content
Online Content
Coffee The old “ meets the requirements of “ issue.
If you want the job done right......do it yourself.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: BigJohn] #5104847 05/14/19 05:39 AM
K
krismoriah72 Offline
K
[Linked Image]
well you didnt get the T6 15w40.. the T6 has 'all the JASO ratings' same as T4.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5104863 05/14/19 06:04 AM
dnewton3 Offline
Global Moderator
Global Moderator
That lube, as well as many others, is not licensed.
Shell (SOPUS) is assuring us it "meets the requirements" of MA/MA2.
This is likely because it's not worth the money for the full license, when they know that Rotella is a small market for bikes. But they also know it would qualify, if tested.
This is not unique; there are many premium lubes that don't always seek full license for all applications, and they claim "meets requirements" ...
Amsoil, RL, RP and some others do this. Does that stop the faithful from using them just because they don't have the license? No it does not.
I use Rotella T4 15w-40 in my Victory, and it does just find by me. It "meets requirements" but is not licensed. And I sleep well at night.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5104916 05/14/19 07:31 AM
K
kschachn Online Content
Online Content
K
Yes, actual JASO MA/MA2 rated oil must be labeled as such in accordance with Appendix 5 of this document:
http://www.jalos.or.jp/onfile/pdf/4T_EV1904.pdf
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: dnewton3] #5104955 05/14/19 08:08 AM
blupupher Offline
I agree, as I stated, but was just wanting it clear it is not an officially approved MA/MA2 oil for those that are concerned with warranty, since using it under a warranty could be used to void any clutch or engine issues.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: blupupher] #5104996 05/14/19 09:15 AM
B
Bonz Offline
B
Shell rates it for motorcycle use. Their reputation is on the line, I know of not a single incident where any Rotella 15w40 oil has caused a problem in a shared sump. Playing the warranty card to cast doubt is over and done with, it isn’t an issue.
Re: Rotella T6 15w-40 Is JASO MA2 Rated [Re: ad244] #5105000 05/14/19 09:16 AM
A
AuthorEditor Offline
A
Long time no post, but I am just about out of my stash of "old" formula T6 5W-40 so I came back here to see what is the latest and greatest. Low and behold, another oil controversy. What fun! My two cents is that I have been using the old T6 for close to 39,000 miles in my Kawasaki EX500 with absolutely no issues, changing about every 3000 miles or one season for a few years I didn't ride the bike much. I would be somewhat wary about going to T6 15W-40 simply for the cold startup issue. Yes, I rarely start when it is below freezing, but the bike may have cold soaked overnight well down into single digits or below. Even with starts in the low 40s the motor definitely spins better with the 5W as opposed to the 15W. In fact, I noticed a significant difference in how my boat diesel starts going from 15W-40 to 10W-30 semi-syn, and most of those starts are well above freezing. I've noted the same thing when comparing 5W-30 dino and 5W-30 synthetic in a variety of cars. There is a noticeable difference even around freezing, and when you get down to zero and below the difference in starting is significant. How much the easy starting of the motorcycle relates to the synthetic bit vs the W rating I don't know, but it just seems logical that an easier start is good for the engine. On the other end of the thermometer I have made many summer trips using the old T6 5W-40 with temperatures in the 90s with the engine running 6-7K with no complaints. Probably the ideal would be to run the T6 15W-40 in the summer and the T6 5W-40 in the spring and fall. May just do that, though I prefer to keep things simple. My opinion on the JASO MA rating is that it is great Shell at leasts lets us know it meets the spec. I would rather use an oil that lets me know that information up front instead of making us guess that other HDEOs are OK.
