Originally Posted by WishIhadatruck
2001 4 Door Grand Prix GT, 3800 V6 with 4T65E trans.
Trans History:
May 2001: Purchased new
12/06/2003, 30,026 miles: Dropped the pan, changed the filter, refilled with 7.5 qts of Mobil 1 ATF
3/25/2006 60,800 miles: Added a ATF cooler
3/26/2006 60,820 miles: Dropped the pan, changed the filter, refilled with 7.5 qts of Mobil 1 ATF
8/23/2008 90,690 miles: Dropped the pan, changed the filter, flushed with 2.5 qts of leftover Mobil 1 ATF (DexIIIh) and 12+ qts of GM Vehicle Care Dex VI.
1/4/2010 121,108 miles: Dropped the pan, changed the filter, installed ZZPerformance shift kit, refilled with 8 qts of Valv. Dex VI.
3/24/11 150,009 miles: Dropped the pan, changed the filter, refilled with 8 qts of Valv. Dex. VI.
Sometime around 110k I started to have issues with the car slamming from gear to gear. It would mostly do this when running in hotter weather doing stop and go driving. It apparently is a common problem where the trans. thinks it isn't shifting fast enough (solenoid issue?) and defaults into a fail safe mode where it max.'s out the pump pressure. You hear lots of pump whine and the shifting gets incredibly hard. I installed a shift kit at the 120k mile pan drop and that seemed to pretty much fix the issue. Much cheaper than dropping the trans. to replace some valves. It will occasionally shift a little more firmly when hot but never like before. More recently (last summer) it was often kicking in and out of torque converter lock-up. Another not so uncommon problem with this trans apparently. By playing with the throttle you could minimize it but it was annoying and I was concerned with the additional wear. Researching it, I found there were multiple causes. To me it felt like the computer could just not make up its mind. I disconnected the battery for an afternoon last fall and it never really did it again. Maybe slightly during the next week or so but that was many months ago and so far so good, zero issues since. Due to those two issues I was wondering how valuable a UOA would be since I expected some extra wear metals and debris due to those two issues. I never saw anything unusual in my pan drops, even pulling the filter apart. This recent pan drop was no different. The pan looked very clean and the inside of the filter was very clean also.
Blackstone Coments: The universal average column along the right side of this page shows typical wear for a GM 4T65E transmission after about 40,000 miles on the oil. You ran this oil 30,000 miles, and wear accumulation was well below average across the board, which is a very good indication that your transmission's internal parts are all functioning properly at 179,999 miles. The viscosity was correct for ATF and no moisture or insolubles were found. The TAN came back at 1.4, showing only a normal amount of acidity present. Keep doing what you are doing. Your transmission looks good.
Comments welcome. I've got Redline D4 in it now. I did a pan drop with a filter change (8 qts) and flushed another 4 qts thru it for a total of 12 qts used. If I still have the car in another 90k miles I'll test it again.
I guess used Dex VI is still thinner than used M1 Dex IIIh. I can't complain about the wear however, especially considering the issues I had during this 90k mile period.
Code
OIL Valv Dex VI M1 DexIIIh
MILES IN USE 30k 30k Uni Avg
MILES 180k 90.5k
SAMPLE TAKEN 07/21/12 08/23/08
ALUMINUM 2 4 8
CHROMIUM 0 0 0
IRON 25 79 81
COPPER 54 113 112
LEAD 10 58 54
TIN 1 4 3
MOLYBDENUM 0 0 1
NICKEL 0 1 1
MANGANESE 0 1 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 1 2 2
BORON 72 83 86
SILICON 4 5 8
SODIUM 3 9 5
CALCIUM 69 132 142
MAGNESIUM 1 3 2
PHOSPHORUS 193 382 294
ZINC 11 11 45
BARIUM 0 0 0
INSOLUBLES 0 TR
WATER 0 0
FLASHPOINT �F 390 405
SUS VIS 210�F 44.0 45.0
cSt @ 212�F 5.41 5.72
TAN 1.4 1.4
