Has anyone here used Aisin WS to replace Toyota WS? I'm assuming it's the exact same fluid since Toyota owns most of Aisin AFAIK. I have a used 2011 Sienna with a U660E automatic and have done a drain and fill @ 70,342 miles with about 2.5 quarts of original Toyota WS. It is likely the first time any of the ATF has been replaced since there are no signs that the fluid has been serviced before. The fluid came out fairly dark so I plan on doing additional drain and fills but the Toyota WS is expensive at $10.01/qt. I have some Aisin WS ordered which cost $7.31/qt so I could save some money doing additional drain and fills. Not interested in changing the fluid out with anything other than "factory" fluids so please don't mention Valvoline....
