I drained and replaced ATF fluid in my 2017 Kia Forte and while doing so I found an annoying design flaw in my car. According to the repair manual, you simply have to heat up the engine, drain and then remove the air intake/air filter to be able to access the fill plug on the top of the transmission. Well, for some reason, the piece that connects to my gear stick was too close to the fill plug and I was unable to remove the plug because a portion of it sat on top of it. I tried to wiggle it out and do anything I could and it simply would not come off. Nothing in the repair manual states this piece has to be removed and the few videos or forums I have seen have not mentioned this so I can only assume it was a build flaw on my car. So, I ended up getting a fluid pump and pumping in 4 QT's through the level indicator port after I raised up the front part of the car. An annoying process but I got it done. I leveled the car back out, got it to temp and a nice little stream came out of the level indicator. A 1 hour job became three but that's ok. Here are some photo's so you can see the process. Anyone else see this before?
