edelbrock carb
by BeerCan - 08/18/19 02:43 PM
Will 2015 5.0 Coyote Notice the Difference?
by BISCUT - 08/18/19 02:37 PM
Fleetguard Fuel Filter FF5301 (4)
by Bighorn2500 - 08/18/19 02:04 PM
AC Compressor
by borgward - 08/18/19 01:40 PM
MK7.5 GTi- Oil and Injector cleaner
by Striker - 08/18/19 12:17 PM
Cheap Hack for Cheap Sunglasses
by RayCJ - 08/18/19 10:55 AM
Detailed Engine using Infinity Wax Rubber Wax
by buster - 08/18/19 10:52 AM
Nissan 15208 9E01A oil filter
by passgas55 - 08/18/19 10:35 AM
by buster - 08/18/19 10:01 AM
Bad oil pressure sensor?
by HoosierJeeper - 08/18/19 10:00 AM
So many oil changes, so little time....
by cwhard - 08/18/19 09:10 AM
What oil did iroc use?
by Red91 - 08/18/19 09:09 AM
Differential cover "load bolts"?
by kehyler - 08/18/19 07:39 AM
Havoline Box
by JLTD - 08/18/19 07:17 AM
Best Oil Change Ramps ??
by billt460 - 08/18/19 05:20 AM
About the original manual recommended viscosity
by dolala - 08/18/19 05:19 AM
Is Z&P concentration extrapolable from SAPS % ?
by FordCapriDriver - 08/18/19 01:36 AM
HardCoreHawkFan, JustChuck, AGs61Vette, KsEXL, madscientist7
68991 Registered Users
91 registered members (AHernandez, 1foxracing, 2KBMW, AZjeff, Al, 13 invisible), 2,400 guests, and 26 spiders.
Topics293,464
Posts5,040,761
Members68,991
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Towing in automatic transmission? [Re: Silk] #5102390 05/11/19 09:13 AM
R
road_rascal Offline
R
Originally Posted by Silk
Not a nation of towers - you need a truck to pull a massive load like that. In NZ we pull bigger loads than that, with smaller cars than that, and we have lots of hills. Totally capable, don't sweat about it, our roads aren't littered with small cars that carried big loads.
You got that right. The few times I've been to NZ (North and South islands- my daughter lives in Auckland) the huge caravans being towed by small hatchbacks was incredible.
2012 Toyota Rav4 V6 4WD (88,000 mi)
2018 Chevy Equinox 1.5T (16,000mi)
Re: Towing in automatic transmission? [Re: maverickfhs] #5104138 05/13/19 11:00 AM
M
meep Offline
M
Do not tow in overdrive. I'm sure it will drive fine and there will be no discernible difference that you can tell. BUT, and there are many discussions on this, the "driven gear" in these ratios develop more heat with less ability to shed it, affecting the fluid in the mesh and potentially impacting those gears and components. While that's vague, and folks can argue it and provide equally vague information, my statement comes from an instrumented study I read years ago where they did thermal analysis on the transmission.
YMMV, but I won't tow in OD.
My 2018 F150 won't let me do so, either, and actually torque-limits the top 2 gears to approximately 1/3 of the throttle.
2018 F150
2015 crv (wifey!)
Re: Towing in automatic transmission? [Re: maverickfhs] #5104375 05/13/19 03:30 PM
E
E365 Offline
E
1,200 lbs. is nothing for most economy cars.
I’ve towed over 5,000 miles with my 1.0 liter 3-cylinder turbo Ford Focus (6M transmission) and a 5x8 enclosed trailer. 750lbs empty and I load up to 750 of cargo for 1,500 lbs total.
I’m in a hilly area and climb a 12% grade routinely. It’s a breeze, up and down. The only time I feel it “struggles” is past about 60 MPH on the freeway due to the aerodynamic drag. I cruise in 5th and climb in 4th at those speeds. That wouldn’t be much of an issue with an open motorcycle trailer though.
Whatever's on sale...
Re: Towing in automatic transmission? [Re: maverickfhs] #5104552 05/13/19 07:05 PM
M
maverickfhs Offline OP
M
Was able to smoothly do it. Thanks all smile
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Towing in automatic transmission? [Re: maverickfhs] #5104555 05/13/19 07:11 PM
M
M
Actually I used D3 everywhere and never pushed engine or brakes or anything, was a good experience wink
Re: Towing in automatic transmission? [Re: maverickfhs] #5104718 05/13/19 10:15 PM
G
GZRider Offline
G
I see I'm late to this party but I was gonna say your engine and transmission would be the least of my concerns to pull that, if anything it would be issues with handling and braking in very strong crosswinds or emergency braking at highway speeds especially if there was rain or snow. Civics and Corolla's are pretty tough little cars.
Re: Towing in automatic transmission? [Re: maverickfhs] #5104846 05/14/19 06:37 AM
M
madRiver Offline
M
Glad it worked out. I think your setup will be fine until an emergent stop or steep hill comes along then you’ll realize the setup is sketchy.
Re: Towing in automatic transmission? [Re: maverickfhs] #5104872 05/14/19 07:21 AM
M
meep Offline
M
That's a nice setup above, E365
2018 F150
2015 crv (wifey!)
Page 2 of 2 1 2
