Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
Ford Motorcraft FL-820S Cut Open
by ThirdeYe - 09/18/19 07:12 PM
AC Delco PF47E cut open
by ThirdeYe - 09/18/19 07:07 PM
JDubyah, 05SentraRed, TSpinner, bbrown, Firemedic15
69326 Registered Users
81 registered members (97prizm, ATex7239, 4WD, 53' Stude, Andrei, atikovi, 11 invisible), 1,259 guests, and 25 spiders.
Topics294,764
Posts5,066,121
Members69,326
Most Online3,532
Jul 30th, 2019
Maintenance tips for HE washer #5104265 05/13/19 01:18 PM
R
RazorsEdge Offline OP
R
We moved to a new rental home and it has a HE washer and dryer. I'm looking for maintenance tips for taking care of these appliances.
One tip I do know of is leaving the front door open after finishing washing so the seal can properly dry to avoid mold issues.
2015 Ford Escape Ecoboost 1.6
Schaeffers 9000 5w20 / Fram Ultra
1987 Mustang GT
Vortech Supercharged
Schaeffers 7000 10w30
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104275 05/13/19 01:39 PM
E
Ed_Flecko Offline
E
Check to see if the washer has a "cleaning cycle", and run that cycle from time to time. Depending on what type of soap has been run through it, the machine may have a lot of soap build-up that may adversely impact the sensors and it may not run as efficiently as possible.
I discovered this cleaning cycle on my LG washer by accident and the first time I ran the cycle, it washed out a TON of soap build-up!
smile
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104282 05/13/19 01:49 PM
A
Alfred_B Offline
A
There's usually a filter at the bottom that prevents lint from going into the drain. Clean that every few years.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104288 05/13/19 01:56 PM
B
BMWTurboDzl Offline
B
Avoid liquid fabric softeners.
Only use HE detergent and follow fill directions.
Run a "Sanitizer" wash once in a while with the appropriate citric acid cleaner.
Keep front door ajar and wipe rubber seal with a towel to mop up the little bit of water which collects at the bottom.
435i
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104296 05/13/19 02:09 PM
Sluggo0018 Offline
Our GE front loader has an access panel on the lower front. Behind it is a strainer to catch debris that has gone through the machine. Open and clean it periodically (quarterly?). It tends to collect a lot of stuff. Have a small catch pan or absorbent towel ready to catch the liquids.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104323 05/13/19 02:35 PM
Donald Offline
The single most important thing to do is to check pockets for stuff. Especially things that can cut or damage the door seal.
Level it side to side, front to back.
As others have said clean out the filter that is under the machine.
Use HE detergent, follow directions, a little less is better than a little more. Clean washing machine cleaner every month or two.
Shake out dog beds before washing to get off the dog hair.
2015 Ford F250 w/Powerstroke
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104328 05/13/19 02:37 PM
skyactiv Offline
Don't overload it. Be gentle when opening/closing the door/drawers. A lot of people are rough and don't realize it or don't care.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Maintenance tips for HE washer [Re: BMWTurboDzl] #5104340 05/13/19 02:55 PM
Donald Offline
Why avoid liquid fabric softener.
Re: Maintenance tips for HE washer [Re: skyactiv] #5104344 05/13/19 02:57 PM
Donald Offline
I agree with the suggestion not to overload it. But filling it is fine and sometimes beneficial. Our GE washer will not spin one or two towels, Unbalanced. But 5 or more is fine.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104356 05/13/19 03:15 PM
Donald Offline
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104393 05/13/19 03:49 PM
Char Baby Online Content
Online Content
Don't use those saop pods. They may be OK in really hot water but the pod itself doesn't fully dissolve in the cold. And it'll cause issues down the road.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104444 05/13/19 04:40 PM
gathermewool Offline
Everything has been covered. Close thread, please!
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Maintenance tips for HE washer [Re: Char Baby] #5104481 05/13/19 05:38 PM
L
Leo99 Offline
L
We stopped using the pods and switched to liquid.
I sanitize when it starts to stink. Stinks a lot more often in the summer than winter. I run a little bleach through it during the sanitize cycle. Tried vinegar and whatnot but bleach worked the best. And it's cheap enough.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104521 05/13/19 06:22 PM
B
benjy Offline
B
HE front loaders are great especially if belt driven, direct drive not so much. the clean cycle usually uses bleach, but using white vinegar as a softener substitute works well.
Re: Maintenance tips for HE washer [Re: gathermewool] #5104527 05/13/19 06:30 PM
Bud Offline
Thanks for the input. Very helpful.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
