belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
28 registered members (aleneros, carviewsonic, Bogdon, Bailes1992, CATERHAM, AnthemBassMan, 1 invisible), 1,255 guests, and 22 spiders.
Topics301,894
Posts5,204,873
Members70,798
Fram PH/TG/XG8A + HP1 flow rate #5104348 05/13/19 02:05 PM
RDY4WAR Offline OP
I sent a request to Fram about the flow rates of the PH8A, TG8A, XG8A, and HP1 filters. I was curious how the new staff there might respond. Here is the response I received from them.
Per our engineering team all filters are tested at ISO 4548-12 test standards. The test is performed with MIL-H-5606 oil at 40 C temperature. The filters are only tested at 3GPM per test requirements. Here are the restriction results for each model:
PH8A: 1.8 PSI @ 3GPM
TG8A: 1.8 PSI @ 3GPM
XG8A: 1.5 PSI @ 3GPM
HP1: 1.45 PSI @ 3GPM
A search for MIL-H-5606 technical properties showed a KV40 of 13.8 cSt.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104358 05/13/19 02:17 PM
CR94 Offline
Interesting reply, and surprisingly straightforward.
Thanks!
2011 Toyota Prius now at 109K
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104365 05/13/19 02:21 PM
5
555 Offline
5
Thanks for the post. I use an HP-1 on the Mustang and was always curious.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104378 05/13/19 02:37 PM
rollinpete Offline
Thanks for posting this information. thumbsup
Correct me if i'm wrong ,but would this mean the oil flows easier thru the XG8A, compared to the TG8A?
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
Shell Rotella Gas Truck 5w30
www.youtube.com/channel/UCFFOhps9dt9yNI_o19vImdA/featured
Currently under the influence of oil shocked2
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104379 05/13/19 02:38 PM
RDY4WAR Offline OP
I sent the same request to WIX regarding the 51515, 51515XP, and 51515R filters. Their response was...
We can't give out that information.
no-no
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: rollinpete] #5104381 05/13/19 02:38 PM
RDY4WAR Offline OP
Yes. Less restriction at the same flow rate while also filtering better.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104390 05/13/19 02:49 PM
rollinpete Offline
Thanks!
Pete.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104412 05/13/19 03:15 PM
K
kschachn Offline
K
Is the difference significant?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: kschachn] #5104458 05/13/19 03:55 PM
CT8 Offline
That was my first thought.
2015 F150 2.7
2018 F350 6.2
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104473 05/13/19 04:26 PM
blupupher Offline
I would think not, only 0.3 psi difference, and vehicles have what, 30-60 psi systems?
But my thoughts have been wrong before, I really have no idea.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104477 05/13/19 04:32 PM
CR94 Offline
Are smaller filters tested at proportionately lower flow rates, or the same? If the same, pressure drop would go considerably higher.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104518 05/13/19 05:18 PM
rollinpete Offline
Looking at them numbers now for a while and they don't seem right?
If I managed to get my truck to go 90 down the highway and get the oil pressure up to 50 psi on the xg8a filter i'd be pumping 100 gpm of oil.
Can anyone explain this to a simple folk like me. LOL
Pete.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: rollinpete] #5104525 05/13/19 05:29 PM
Z
ZeeOSix Offline
Z
Pressure drop (delta-p) across the oil filter has nothing to do with how much oil pressure you see on the dashboard gauge.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104530 05/13/19 05:36 PM
Z
ZeeOSix Offline
Z
Go info, thanks for posting. 13.8 cSt is like a light 40 weight at 212 deg F.
Here's a couple of delta-p vs flow graphs for comparison. One is the PureOne from Purolator that shows delta-p vs flow with hot oil of about the same viscosity. Also a graph of the Ford Racing filter with unknown oil viscosity, but it would have to be relatively hot oil IMO to obtain a graph like that. Looking at 3 GPM on the graph, the PureOne is 1.2 PSID and the Ford Racing is 2.5 PSID.
As mentioned many times, most oil filters out there will not have much delta-p with hot oil ... way less than most people would think. Even at 10 GPM, the delta-p will only be 4 to 5 PSID with hot oil.
Re: Fram PH/TG/XG8A + HP1 flow rate [Re: RDY4WAR] #5104535 05/13/19 05:41 PM
RDY4WAR Offline OP
The secret to the better flow with the Purolator is the tear in the media. laugh
