I am looking at a pristine truck as listed above. It has the installed towing package. 4WD. 72000 miles. It was not used for towing however if purchased will used for towing a small boat and ATVs on an appropriate trailer. The listed specs I have seen when searching indicates a 6000 lb. towing capacity but 2WD models with the 3.0 is half as much.
Are there any members on the forum with experience with the truck especially with the automatic transmission that can give some insight about the durability of the drive train, towing capacity and the 4.0 V6 engine?
Thanks
Thanks
