Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
115 registered members (01rangerxl, 4WD, 2015_PSD, 77GrandPrix, 14 invisible), 1,946 guests, and 27 spiders.
Topics292,007
Posts5,015,078
Members68,692
Most Online2,967
Mar 10th, 2019
Maintenance tips for HE washer #5104265
05/13/19 01:18 PM
05/13/19 01:18 PM
USA
RazorsEdge Offline OP
USA
We moved to a new rental home and it has a HE washer and dryer. I'm looking for maintenance tips for taking care of these appliances.
One tip I do know of is leaving the front door open after finishing washing so the seal can properly dry to avoid mold issues.
2015 Ford Escape Ecoboost 1.6
Schaeffers 9000 5w20 / Fram Ultra
1987 Mustang GT
Vortech Supercharged
Schaeffers 7000 10w30
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104275
05/13/19 01:39 PM
05/13/19 01:39 PM
California
Ed_Flecko Offline
Ed_Flecko  Offline
California
Check to see if the washer has a "cleaning cycle", and run that cycle from time to time. Depending on what type of soap has been run through it, the machine may have a lot of soap build-up that may adversely impact the sensors and it may not run as efficiently as possible.
I discovered this cleaning cycle on my LG washer by accident and the first time I ran the cycle, it washed out a TON of soap build-up!
smile
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104282
05/13/19 01:49 PM
05/13/19 01:49 PM
America
Alfred_B Offline
Alfred_B  Offline
America
There's usually a filter at the bottom that prevents lint from going into the drain. Clean that every few years.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104288
05/13/19 01:56 PM
05/13/19 01:56 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Avoid liquid fabric softeners.
Only use HE detergent and follow fill directions.
Run a "Sanitizer" wash once in a while with the appropriate citric acid cleaner.
Keep front door ajar and wipe rubber seal with a towel to mop up the little bit of water which collects at the bottom.
435i
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104296
05/13/19 02:09 PM
05/13/19 02:09 PM
Long Valley, NJ
Sluggo0018 Offline
Sluggo0018  Offline
Long Valley, NJ
Our GE front loader has an access panel on the lower front. Behind it is a strainer to catch debris that has gone through the machine. Open and clean it periodically (quarterly?). It tends to collect a lot of stuff. Have a small catch pan or absorbent towel ready to catch the liquids.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104323
05/13/19 02:35 PM
05/13/19 02:35 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The single most important thing to do is to check pockets for stuff. Especially things that can cut or damage the door seal.
Level it side to side, front to back.
As others have said clean out the filter that is under the machine.
Use HE detergent, follow directions, a little less is better than a little more. Clean washing machine cleaner every month or two.
Shake out dog beds before washing to get off the dog hair.
2015 Ford F250 w/Powerstroke
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104328
05/13/19 02:37 PM
05/13/19 02:37 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Don't overload it. Be gentle when opening/closing the door/drawers. A lot of people are rough and don't realize it or don't care.
Me: 13' VW GTI 3 door 6 speed manual
Re: Maintenance tips for HE washer [Re: BMWTurboDzl] #5104340
05/13/19 02:55 PM
05/13/19 02:55 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Why avoid liquid fabric softener.
Re: Maintenance tips for HE washer [Re: skyactiv] #5104344
05/13/19 02:57 PM
05/13/19 02:57 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I agree with the suggestion not to overload it. But filling it is fine and sometimes beneficial. Our GE washer will not spin one or two towels, Unbalanced. But 5 or more is fine.
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104356
05/13/19 03:15 PM
05/13/19 03:15 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104393
05/13/19 03:49 PM
05/13/19 03:49 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Don't use those saop pods. They may be OK in really hot water but the pod itself doesn't fully dissolve in the cold. And it'll cause issues down the road.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104444
05/13/19 04:40 PM
05/13/19 04:40 PM
New England
gathermewool Offline
New England
Everything has been covered. Close thread, please!
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: Maintenance tips for HE washer [Re: Char Baby] #5104481
05/13/19 05:38 PM
05/13/19 05:38 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
We stopped using the pods and switched to liquid.
I sanitize when it starts to stink. Stinks a lot more often in the summer than winter. I run a little bleach through it during the sanitize cycle. Tried vinegar and whatnot but bleach worked the best. And it's cheap enough.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Maintenance tips for HE washer [Re: RazorsEdge] #5104521
05/13/19 06:22 PM
05/13/19 06:22 PM
pa
benjy Offline
benjy  Offline
pa
HE front loaders are great especially if belt driven, direct drive not so much. the clean cycle usually uses bleach, but using white vinegar as a softener substitute works well.
Re: Maintenance tips for HE washer [Re: gathermewool] #5104527
05/13/19 06:30 PM
05/13/19 06:30 PM
Texas
Bud Offline
Bud  Offline
Texas
Thanks for the input. Very helpful.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
