95 registered members (Astro14, b1amgm47, 06_lx, 69Torino, ArrestMeRedZ, AP9, 8 invisible),
2,165
guests, and 27
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,797
Posts5,141,352
Members70,124
Most Online3,589 Nov 2nd, 2019
Maintenance tips for HE washer
#5104265
05/13/19 12:18 PM
RazorsEdge
OP
OP
Posts: 652 |
We moved to a new rental home and it has a HE washer and dryer. I'm looking for maintenance tips for taking care of these appliances.
One tip I do know of is leaving the front door open after finishing washing so the seal can properly dry to avoid mold issues.
2015 Ford Escape Ecoboost 1.6 Schaeffers 9000 5w20
1987 Mustang GT Vortech Supercharged Schaeffers 7000 10w30
Re: Maintenance tips for HE washer
[Re: RazorsEdge]
#5104275
05/13/19 12:39 PM
Ed_Flecko
Posts: 829 |
Check to see if the washer has a "cleaning cycle", and run that cycle from time to time. Depending on what type of soap has been run through it, the machine may have a lot of soap build-up that may adversely impact the sensors and it may not run as efficiently as possible. I discovered this cleaning cycle on my LG washer by accident and the first time I ran the cycle, it washed out a TON of soap build-up!  Ed
K-9s teach the suspect that if you run...you'll only be arrested tired. Support YOUR local law enforcement K-9 Unit! https://www.ssdk9.com/
[Re: RazorsEdge]
#5104282
05/13/19 12:49 PM
Alfred_B
Posts: 2,590 |
There's usually a filter at the bottom that prevents lint from going into the drain. Clean that every few years.
[Re: RazorsEdge]
#5104288
05/13/19 12:56 PM
BMWTurboDzl
Posts: 4,338 |
Avoid liquid fabric softeners.
Only use HE detergent and follow fill directions.
Run a "Sanitizer" wash once in a while with the appropriate citric acid cleaner.
Keep front door ajar and wipe rubber seal with a towel to mop up the little bit of water which collects at the bottom.
435i
[Re: RazorsEdge]
#5104296
05/13/19 01:09 PM
Sluggo0018
Posts: 86 |
Our GE front loader has an access panel on the lower front. Behind it is a strainer to catch debris that has gone through the machine. Open and clean it periodically (quarterly?). It tends to collect a lot of stuff. Have a small catch pan or absorbent towel ready to catch the liquids.
[Re: RazorsEdge]
#5104323
05/13/19 01:35 PM
Donald
Posts: 23,294 |
The single most important thing to do is to check pockets for stuff. Especially things that can cut or damage the door seal.
Level it side to side, front to back.
As others have said clean out the filter that is under the machine.
Use HE detergent, follow directions, a little less is better than a little more. Clean washing machine cleaner every month or two.
Shake out dog beds before washing to get off the dog hair.
2015 Subaru Forester 2.5 engine/CVT 2015 Ford F250 w/Powerstroke 2016 Subaru Crosstrek CVT (wife's)
[Re: RazorsEdge]
#5104328
05/13/19 01:37 PM
skyactiv
Posts: 6,164 |
Don't overload it. Be gentle when opening/closing the door/drawers. A lot of people are rough and don't realize it or don't care.
Wife: 15' Audi A4 quattro 6 speed manual Sold: 13' VW GTI 3 door 6 speed manual Me: 18' Elantra Sport 6 speed manual
[Re: BMWTurboDzl]
#5104340
05/13/19 01:55 PM
Donald
Posts: 23,294 |
Keep front door ajar and wipe rubber seal with a towel to mop up the little bit of water which collects at the bottom. Why avoid liquid fabric softener.
[Re: skyactiv]
#5104344
05/13/19 01:57 PM
Donald
Posts: 23,294 |
Don't overload it. Be gentle when opening/closing the door/drawers. A lot of people are rough and don't realize it or don't care. I agree with the suggestion not to overload it. But filling it is fine and sometimes beneficial. Our GE washer will not spin one or two towels, Unbalanced. But 5 or more is fine.
[Re: RazorsEdge]
#5104356
05/13/19 02:15 PM
Donald
Posts: 23,294 |
[Re: RazorsEdge]
#5104393
05/13/19 02:49 PM
Char Baby
Posts: 11,969 |
Don't use those saop pods. They may be OK in really hot water but the pod itself doesn't fully dissolve in the cold. And it'll cause issues down the road.
"Retired" -----------------------------------
'80 Firebird FORMULA V8/4bbl-purchased "NEW" '15 Nissan Altima 2.5 SV '15 Honda Civic 1.8 LX
[Re: RazorsEdge]
#5104444
05/13/19 03:40 PM
gathermewool
Posts: 7,405 |
Everything has been covered. Close thread, please!
14 Forester XT Touring FA20DIT (Cobb Stage 1) Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19) 15 Legacy Premium FB25 Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
[Re: Char Baby]
#5104481
05/13/19 04:38 PM
Leo99
Posts: 4,261 |
Don't use those saop pods. They may be OK in really hot water but the pod itself doesn't fully dissolve in the cold. And it'll cause issues down the road. We stopped using the pods and switched to liquid. I sanitize when it starts to stink. Stinks a lot more often in the summer than winter. I run a little bleach through it during the sanitize cycle. Tried vinegar and whatnot but bleach worked the best. And it's cheap enough.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP) 2004 Corolla 125,000 miles 2004 Rav4 392,000 miles 2015 Camry 90,000 miles
[Re: RazorsEdge]
#5104521
05/13/19 05:22 PM
benjy
Posts: 2,014 |
HE front loaders are great especially if belt driven, direct drive not so much. the clean cycle usually uses bleach, but using white vinegar as a softener substitute works well.
[Re: gathermewool]
#5104527
05/13/19 05:30 PM
Bud
Posts: 2,506 |
Everything has been covered. Close thread, please! Thanks for the input. Very helpful.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
