Apparently it does.
Quote
Digitally tracks torque and angle measurement. Multiple alerts when the
target torque is reached prevent over-torqueing of bolts. Handle vibrates,
buzzer sounds and LCD screen alerts when the target torque is reached
• Three function modes: peak torque, angle and peak angle
• "Target Torque Alert" and "Target Angle Alert" gives a warning as the target
torque or target angle is approached, so there is less chance of
over torqueing a bolt
• Accurate in clockwise direction +/- 2% and +/-3% in a counter-clockwise
direction, from 20% to 100% of full scale
• Angle Accuracy (+/-1% of Reading) + (+/-1 degree @ angular
velocity >10 degree/sec sec) + (+/-1 degree of
test fixture)
• Five torque measurement units are available: Nm, ft-lbs,
in-lbs, kgf-m, kgf-cm
• Ten torque setting presets for frequently repeated applications
• Meets or exceeds ASME B107.300
• Requires 2 AA (alkaline) batteries
