Oil temperature data
by Snagglefoot - 08/25/19 01:30 AM
Broke down and bought a Econobox.
by Blkstanger - 08/24/19 11:41 PM
STP Filters
by HobbledMechanic - 08/24/19 11:02 PM
Alternative oil filters
by GeoffPD - 08/24/19 10:16 PM
PartSource Canada Delvac deal
by Bluestream - 08/24/19 09:57 PM
Chamberlain tractor pto clutch oil
by Jabbo - 08/24/19 09:37 PM
how to get out o2 sensor
by dogememe - 08/24/19 09:18 PM
Should I use a wash and wax for maintenance washes?
by littlehulkster - 08/24/19 08:53 PM
Michelin Rebate
by twouvakind - 08/24/19 08:47 PM
Meguiar's Ultimate Fast Finish.
by irv - 08/24/19 08:27 PM
Fram PH/TG/XG3593a cut open
by SlavaB - 08/24/19 08:12 PM
Supertech vs OEM
by Bettez88 - 08/24/19 08:05 PM
Exxon Mobile Synergy Supreme Friction Modifier
by IndyFan - 08/24/19 07:50 PM
Toyota oil cap funnel
by Patrick0525 - 08/24/19 07:07 PM
STUMPED (2002 BMW X5)
by Kira - 08/24/19 05:43 PM
Turtle Wax Zip wash/wax...garbage!
by gregk24 - 08/24/19 05:41 PM
Does Super Lube Oil make Good Electric Motor Oil
by vortex - 08/24/19 04:40 PM
26 degree temp swing in 24 hours
by gman2304 - 08/24/19 04:12 PM
EricTwoCamaros, Subie5w30, Iautox, Mayadi, YachtRocket
69055 Registered Users
28 registered members (crosspug, 2strokeNorthstar, ABCarr, Bailes1992, Blkstanger, 4WD, 3 invisible), 793 guests, and 23 spiders.
Topics293,758
Posts5,046,207
Members69,055
Most Online3,532
Jul 30th, 2019
(Fuel) Pump physics question? #5103422 05/12/19 01:10 PM
E
Ed_Flecko Offline OP
E
I *think* this is a physics question?
smile
Whether we're talking about a fuel pump, or any other pump that's submersed in a liquid, I've heard that "head pressure" will make the pumping of said liquid easier which in turn means your pump in question will last longer? I've heard the deeper the pump is submerged, the easier it is to pump the liquid.
I never run my gas tank below 1/4 tank, for other reasons, but I've also heard that by doing so your fuel pump will last longer by not overheating (the gasoline lubricates and cools the pump) and by not having to work as hard to pump fuel due to head pressure.
If what I've heard is true, then maybe it's smart to try and keep your tank above 1/2 full to make the work of your fuel pump as effortless as possible?
Thoughts?
Thank you,
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103431 05/12/19 01:26 PM
R
RayCJ Offline
R
Yes, it's a physics questions. No, submerging a pump deeply does not make it easier to pump the fluid. Actually, quite the opposite. As the fluid delivery lines are routed higher above the pump it must work against more gravity to deliver the fluid.
Ray
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103435 05/12/19 01:29 PM
MrMoody Offline
I don't think a fuel tank is deep enough to make any real difference.
What does make a difference is that in-tank electric pumps are cooled by the liquid around them, so running nearly empty deprives them of some of their cooling. If this is done habitually, it can shorten the pump life. I've seen this firsthand.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103440 05/12/19 01:38 PM
E
eljefino Offline
E
In physics, I have a dug (shallow) well, and the pump is in my basement. This only really works down to 25 feet, because at 30 feet, you can pull a perfect vacuum and the water will just stay down there.
If I had a deeper well, I could put the pump down there and it could pump upwards a nearly unlimited number of feet, depending on its design.
An in-tank fuel pump can dead-head 150 psi, though only 60 are needed on your typical port injection setup.
A carbureted "lift" pump makes around 5-6 psi, same as an engine-mounted mechanical pump. The lift pump won't vapor-lock, though, and is "better" since it's not drawing a partial vacuum to get fluid (with a propensity for evaporation) where it needs to go.
Lifting gasoline 2 or 3 feet to get up to carburetor/ injector level is no challenge, so an empty vs full tank doesn't really matter in that regard.
Re: (Fuel) Pump physics question? [Re: MrMoody] #5103442 05/12/19 01:46 PM
MolaKule Offline
Global Moderator
Global Moderator
I think it is a "washout" as well in terms of a fuel pump
While you may have some fluid pressure sitting on top of a pump, the pump must provide enough pressure for the 'uphill" pumping to the fuel supply system.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103471 05/12/19 02:16 PM
RDY4WAR Offline
I third the notion that it won't make any distinguishable difference.
As some anecdotal info, I have experienced 3 fuel pump failures in my life. All 3 occurred right after filling up the tank.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: (Fuel) Pump physics question? [Re: MrMoody] #5103488 05/12/19 02:36 PM
B
benjamming Offline
B
I'm pretty sure that they're primarily cooled by the fluid going through them.
Re: (Fuel) Pump physics question? [Re: benjamming] #5103513 05/12/19 03:12 PM
T
The_Eric Offline
T
You could well be right.
I'll also say that basically all pumps after the early 2000s or thereabouts are sitting in their own module which has a check valve to let fuel in but not back out. Therfore the tank can be nearly empty but the pump will still be immersed in fuel. My understanding is that it was done to prevent lean misfires from low fuel pressure when maneuvering with a low fuel level. Even a lean misfire will still release extra hydrocarbons into the cat, thus shortening its life.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: (Fuel) Pump physics question? [Re: RayCJ] #5103576 05/12/19 04:41 PM
A
ammolab Offline
A
Ray
The question doesn’t move the pump position deeper but just raises the level of fluid above it. The pump remains stationary in the same position below its delivery lines, so no more gravity exists as you fill the tank.
But yes, Not enough to matter.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: (Fuel) Pump physics question? [Re: eljefino] #5103606 05/12/19 05:26 PM
R
Rand Offline
R
I'd agree except your example is flawed shallow and deeper jet pumps... you can go way below 30ft with a jet pump..
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103621 05/12/19 05:49 PM
M
mk378 Offline
M
In a simple well with a pump at the top of the well and a suction pipe to the bottom, atmospheric air pressure on the surface of the water is the only force available to bring water up to the pump. This does indeed stop working around 25 feet.
The "deep well" version of the jet pump cycles some pressurized water down the well to operate an ejector below the surface. This can bring water up from a much greater depth, though still not unlimited. The system requires installing two pipes from the pump to the well, though they are occasionally installed as a small pipe inside a larger pipe.
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5103783 05/12/19 09:12 PM
Shannow Offline
The principal is "Nett Positive Suction Head", maintaining a pressure such that at the inlet of the pump, the column of fluid doesn't "separate", in the worst case (eljefino's example), or cavitate (still pump but have the fluid form bubbles (cavities)) that cause a loss of volume and damage.
It's referenced in terms of absolute vacuum, not gauge, so yes a pump can provide a degree of lift if situated above the surface of the fluid and properly primed.
It has to take into account the strainers and lines leading to the pump suction, the vapor pressure of the fluid, and how that changes with temperature.
there's some really cool examples of NPSH control in power stations (dearator tanks located on a floor 100 feet up, condensate pumps having a 5 metre extension piece in the middle, and the impeller located 20 feet below ground level so that there's enough "weight" of water to provide NPSH in a vacuum)
If it's the truth....it can handle the pressure !!!
Re: (Fuel) Pump physics question? [Re: Ed_Flecko] #5104462 05/13/19 05:01 PM
R
red7404 Offline
R
let me see. gasoline with electric wires in there? what can go wrong?
Re: (Fuel) Pump physics question? [Re: red7404] #5104475 05/13/19 05:29 PM
T
The_Eric Offline
T
Obviously not an issue since there's millions of them out there. The mere presence of electricity in a gas tank isn't an issue. Even if they were arcing it probably wouldn't do anything since theres likely not enough oxygen to support combustion.
Re: (Fuel) Pump physics question? [Re: MrMoody] #5105081 05/14/19 11:48 AM
supton Offline
I've always heard that, just haven't seen it--but the only high mileage car I had did puke its fuel pump around 250k, and I routinely go down to 2 gallons or so in the tank. But that car also did have a fuel cooler so it truly did have some high fuel temps I suspect.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 209k, his
