TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Milwaukee 2485-20 M12 1/4” Right Angle Die Grinder
by The Critic - 10/21/19 12:41 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
Fram Ultra or Mobil 1 for Jeep JK?
by SkipCam - 10/20/19 06:42 PM
whizznbyu, Oildude, JDVW2019, Carlos40A, GeraldT
69624 Registered Users
32 registered members (2015_PSD, AEHaas, Best F100, Bailes1992, bernau, 4 invisible), 782 guests, and 25 spiders.
Topics296,250
Posts5,094,218
Members69,624
Most Online3,532
Jul 30th, 2019
Copper ATF Washers for Toyota? #5102962 05/11/19 10:37 PM
G
Gebo Offline OP
G
Just ordered some automatic transmission gaskets for my toyota and lexus. It says they are OEM and are copper. Is this correct? My old ones were aluminum. I thought I read somewhere not to put copper up against aluminum.
35178-30010 part number
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Supertech Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Copper ATF Washers for Toyota? [Re: Gebo] #5102988 05/11/19 11:19 PM
J
JamesBond Offline
J
My old BMWs use copper oem drain plug gaskets against aluminum pans and transmission cases, no problems. I heard that copper is softer than aluminum so it should be used with aluminum pans and cases.
Re: Copper ATF Washers for Toyota? [Re: Gebo] #5103261 05/12/19 09:30 AM
I
incognito_2u Offline
I
Don’t quote me, but I seem to remember bad things happening when Aluminum and Copper “meet”.........something akin to galvanic corrosion.
Wait......disregard. Isn’t the Transmission pan steel?
2006 Jeep Commander 3.7 V6 -114k (PUP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -84k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -88k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -67k (QSUD5W30/XG3600)
Re: Copper ATF Washers for Toyota? [Re: Gebo] #5103286 05/12/19 09:52 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Copper touching aluminum is only a problem in the presence of an electrolyte. If your car is like mine, there is an everpresence of oil around the drain plugs, excluding the electrolyte.
Re: Copper ATF Washers for Toyota? [Re: Kestas] #5103289 05/12/19 09:55 AM
4WD Offline
I use Super Lube for things like that
Re: Copper ATF Washers for Toyota? [Re: Gebo] #5103335 05/12/19 11:07 AM
B
benjamming Offline
B
They've been using that part since at least 1994. No problem to use.
Re: Copper ATF Washers for Toyota? [Re: Kestas] #5104604 05/13/19 08:07 PM
I
I
Yes, I am well aware of that. I was referencing that the external plug of the pan would be subject to debris on the road, Road Salt in the Winter being one of them, which as we know does contain compounds (magnesium, calcium,potassium) that in theory will act as an electrolyte.
But like I stated, it’s a moot point as I believe the pan is made of steel.
