LINK: https://www.moogparts.com/content/d...lete%20Knuckle%20Assembly%20Bulletin.pdf
I really love this idea: it's TWICE the cost of the hub assembly (and 4x the cost of the wheeling bearings alone)
You'll still have to remove the ball joint and the tie-rod to install this but that's a much easier job than removing the hub assembly and/or having the wheel bearings pressed.
I think for the DIY'er with a limited set of tools and/or no garage, this is perfect.
