I have a 1996 Grand Prix that I bought with a bad head gasket (or possible cracked head) with the intention of fixing it up, a project car of sorts. I stored it for a year until I freed up space in my garage this spring so that I can work on it. When I went to move the car into the garage, the brake pedal sank all the way to the floor and brake light illuminated.
I figured out what happened, on a flat spot under the car, near the firewall, there is a plastic bracket where about 5 (or 6) metal lines are secured into. Evidently this created a great location for salt to accumulate and all metal lines are rusted pretty badly in this area. I remember there being three small diameter lines and two larger. I believe the two larger lines to be fuel feed & return.
I'm sure there are tons of people who deal with this often in cold/salt areas who might be able to help me with this. I haven't done any brake line work but given that this is a project car, I have plenty of time to learn and don't want to put heaps of money into it on things I can do myself.
Is it possible to cut out only the affected portion of metal brake line, approx 5" and make a new section with union fittings to join existing line? We don't deal with much salt exposure/vehicle rust here, so the rest of the line is in good, rust-free condition. It's just where this plastic bracket is that it's really ate up.
Then what to do with the [presumably] fuel lines? I don't suppose you can just cut that bad section out..? I thought about using a rubber fuel injection rated hose to join the two good sides together (cut out bad spot) but you'd need to create a nipple on the pipe for it to be leak free. Is replacing the entire line the only option? I'm curious how these types of repairs are typically made, given the frequency people must deal with this on older cars in the rust belt.
