Hey guys,
I have a Bluetooth to OBDII adapter to use with OBD Fusion on my iPhone. I need to check CVT trans temps on 2014+ Subaru TR580/TR690 transmissions. For research I poked around the internet and dug out data from the ScanGauge category for transmission. Example:
Code
NAME TXD RXF RXD MTH NAME NOTE
CVT Fluid Temperature (°F) 07E1221017 C46205103617 3008 00090005FFC6 TFT 4.22+ Required"
This is translated to Torque/OBD Fusion codes like so:
Module/Header: 7E1
OBD Mode: 22 (If Torque, then it's 221017)
PID Number: 1017
Equation: (((A*9)/5)-58)
I tried it in a car today, not no response back. The reason I would like to make this post is to figure out why, because the CVTs on the Subies are really picky, and a lot of us are doing CVT flushes on them. If the fluid is not in the correct temp range (95-113 deg F, 35 - 45 deg C) then it is Not Okay and the easiest way for the common folk like us is to use one of these wireless bridges and a program on our phones.
Can someone else who has one of these setups (Torque/whatever) and a Subie w/CVT check my work?
Code
Module/Header: 7E1
PID Number: 1017
