Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
20 registered members (avi1777, Duffyjr, Deontologist, Duke, ctechbob, 4WD, 4 invisible), 536 guests, and 18 spiders.
Topics293,713
Posts5,045,461
Members69,048
Most Online3,532
Jul 30th, 2019
Hitch Wiring installation? #5095576 05/04/19 10:22 AM
M
maverickfhs Offline OP
M
So I am trying to install a hitch wiring kit, so that I can hook up a motorcycle trailer with the recently installed hitch on Honda Civic.
Can anyone please confirm if I would have to splice the wires after looking at the connector?
I am bit confused, because the kit doesn't look the correct(and butchered) one smile
Thanks for the help.
[Linked Image]
[Linked Image]
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Hitch Wiring installation? [Re: maverickfhs] #5095596 05/04/19 10:46 AM
E
eljefino Offline
E
I assume your civic has separate (amber) turn signals? That diode pack is correct.
You'll need new scotch taps (or splicing or whatever) and you might need more wire if they cut it short. But otherwise it looks legit.
Re: Hitch Wiring installation? [Re: eljefino] #5095605 05/04/19 10:55 AM
M
M
Yes, mine has separate bulbs, I think. It's an 06 Civic EX Coupe, Should I splice the wire or safe install the connectors?
Was told to have a wiring, in order to rent a uhaul motorcycle trailer and hence the need thumbsup
Re: Hitch Wiring installation? [Re: eljefino] #5095606 05/04/19 10:55 AM
M
M
What should I do with the 'black' wire, as it says 'Battery' on it?
Re: Hitch Wiring installation? [Re: maverickfhs] #5095611 05/04/19 11:06 AM
E
eljefino Offline
E
Run it off an ignition only wire-- I like the powered (heated) seats fuse for stuff like this. But first I'd see if it works without it, LOL.
These diode things are cheezy and short out all the time (typically because of the plug dangling under the bumper) so if you hook it to "always positive" it can run your battery down.
Re: Hitch Wiring installation? [Re: eljefino] #5095626 05/04/19 11:32 AM
M
M
Thanks, is there a way I can test it out first to see if it actually is in working condition? I don't want to splice all the wires and realize this whole things is no good laugh
Re: Hitch Wiring installation? [Re: maverickfhs] #5095627 05/04/19 11:36 AM
M
M
This one does not show anywhere 'battery' or black wire or that's an add on kind of thing?
Re: Hitch Wiring installation? [Re: maverickfhs] #5095642 05/04/19 12:03 PM
B
bmod305 Offline
B
It's a powered converter due to the amber tail lights. It protects the towing vehicle electronics for shorts.
Dave
2019 Equinox 2.0T
2007 Grand Prix 3.8na
Re: Hitch Wiring installation? [Re: bmod305] #5095650 05/04/19 12:10 PM
M
M
Dave
Thanks, any idea if it can be used as a non- powered and if I can just ignore black/battery wire? Thank you
Re: Hitch Wiring installation? [Re: maverickfhs] #5095767 05/04/19 04:19 PM
B
bmod305 Offline
B
Has to be powered.
2019 Equinox 2.0T
Re: Hitch Wiring installation? [Re: maverickfhs] #5095770 05/04/19 04:23 PM
skyactiv Offline
I have a powered light converter on my car hooked up to the battery. I have a fuse right off the battery I keep removed unless I'm towing. I forgot to pop the fuse in once and didn't have any trailer lights.
Some vehicles need a PWM type converter. The big advantage to having a powered converter is that trailers with incandescent bulbs will be brighter.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Hitch Wiring installation? [Re: bmod305] #5095786 05/04/19 05:04 PM
M
M
Has to be powered.
Thanks, can I use a 12V cigarette lighter plugin or has to be connected to the battery? I'll have to try a few things before I finalize it.
Re: Hitch Wiring installation? [Re: maverickfhs] #5095836 05/04/19 06:21 PM
R
Rand Offline
R
Has to be powered.
you can get power from the 12v outlet wire.
Re: Hitch Wiring installation? [Re: Rand] #5095986 05/04/19 09:29 PM
M
M
Has to be powered.
Thanks, one last thing, if polarity would matter from cigarette lighter or should I just connect "+" to 'Battery' on the hitch connector and just ground the "-" on the 12V output?
Re: Hitch Wiring installation? [Re: eljefino] #5102066 05/10/19 09:17 PM
M
M
You definitely know a lot!
Everything so far seems to be working well, will find out if it stays like it smile
Thanks all for your help and tips thumbsup
