Guess your never too young to work on a chevy.
by rollinpete. 06/24/19 08:13 PM
Went to Jiffy Lube
by Stelth. 06/24/19 07:37 PM
safest way to remove bug residue
by NissanMaxima. 06/24/19 07:32 PM
22000 emails
by marine65. 06/24/19 06:31 PM
oil analysis to show fuel dilution
by jfairchild327. 06/24/19 06:00 PM
Mitsu 3000GT rear engine mount is tilted...
by tomcat27. 06/24/19 05:52 PM
Engine full of Fuel. What is best to do?
by LeoStrop. 06/24/19 05:50 PM
Seeking Advice Choosing Wheel Locks
by JerryBob. 06/24/19 05:19 PM
Non-stick pan
by Alfred_B. 06/24/19 05:04 PM
Had to ELIMINATE a raccoon
by Kjmack. 06/24/19 04:52 PM
Oil Consumption 6.0L AFM Unicorn?
by tahoe_hybrid. 06/24/19 04:27 PM
PP 5W-20, 3000mi, '14 Kia Soul
by tc1446. 06/24/19 03:07 PM
Cheap powerfull filter magnet
by loneryder. 06/24/19 01:50 PM
New road tire time
by UG_Passat. 06/24/19 01:46 PM
Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
PCV Valve Cleaning Replacement ?
by ChrisD46. 06/24/19 11:54 AM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
123 registered members (77GrandPrix, 97K15004WD, 53' Stude, aba4430, 2010Civic, 11 invisible), 2,254 guests, and 30 spiders.
Topics290,916
Posts4,995,236
Members68,474
Most Online2,967
Mar 10th, 2019
Auto Bleeder Scanner #5100348
05/09/19 08:30 AM
05/09/19 08:30 AM
IL
LAGA Offline OP
LAGA  Offline OP
IL
Went using the Foxwell nt630 elite auto bleed function
Can you open up the bleeder screw and have the ABS unit pump out the old fluid? Or is just for removing air from the ABS unit?
Four legs good, two legs better!
Re: Auto Bleeder Scanner [Re: LAGA] #5100372
05/09/19 08:53 AM
05/09/19 08:53 AM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
I believe it will only remove the air in the ABS pump. Regular bleeding needed after this process.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Auto Bleeder Scanner [Re: KGMtech] #5100427
05/09/19 10:11 AM
05/09/19 10:11 AM
IL
LAGA Offline OP
LAGA  Offline OP
IL
Thanks
Re: Auto Bleeder Scanner [Re: LAGA] #5100429
05/09/19 10:15 AM
05/09/19 10:15 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
The automated bleed function purges air from the ABS module into the lines. You then bleed normally at the wheels. This process should be done first and, ideally, you would run the auto bleed function twice or three times if needed and re-bleed after each time. One note, on my '94 Corvette, there is a bleeder on the ABS module and I actually did the auto bleed and let the fluid run out the bleeder . The I did it again with the bleeder closed and did a brake bleed at the wheels. Worked real nice.
