OVERKILL
$100 Site Donor 2021
Originally Posted by vq40
So climate has nothing to do with the viscosity.
Climate can have a significant impact on viscosity. That's why it was, before CAFE, pretty much standard to have viscosity tables in owner's manuals, which you still see in most other parts of the world. That's why you don't run 20w-50 in Winnipeg in January.
Thinner oil is better due to it dissipates heat way better than thicker,
Talk about hyperbole. Thinner oil takes away heat SLIGHTLY better than a heavier oil. The difference is so small it is barely worth mentioning. Contrarily, heavier oil heats up faster (marginally) than thinner oil because the action of shearing generates heat.
lower drag,
Slightly lower drag, yes.
flows better,
Given that oil pumps are positive displacement, that's incorrect. Actually, a thinner oil will have more "slip" in the oil pump and, if the relief is not open, actually flow LESS.
and with today's engines the oil pump is a low volume oil pump designed for 0w20 oil, oil won't flow correctly with the thicker oil.
That's completely backwards. Thinner oils require more volume to make up for increased side leakage. This is why thinner oils result in lower oil pressure. Engines that spec thinner oils typically have HIGHER volume pumps.
Do yourself a favor and follow what that owners manual says.
That, we can agree on. It is always a safe bet to follow the verbiage laid out in the manual.
lower drag,
flows better,
