Vehicle Insurance Goes Down Again
by BlueOvalFitter. 07/22/19 05:20 PM
2003 Dodge Caravan front brakes
by Oldtom. 07/22/19 04:52 PM
TPMS Sensors for a 2012 Highlander
by Tundragod. 07/22/19 04:43 PM
No one has posted the C8 interior yet?
by wensteph. 07/22/19 04:42 PM
Discard veggies from homemade veggie broth? Really?
by Ed_Flecko. 07/22/19 04:37 PM
Water spot remover
by Redright9. 07/22/19 03:40 PM
Optimal oil temp?
by gfh77665. 07/22/19 03:08 PM
Westlake Tires
by bunnspecial. 07/22/19 03:04 PM
Quick struts
by t1snwrbrdr12. 07/22/19 02:55 PM
Mechanic in Green Bay, WI?
by Y_K. 07/22/19 02:48 PM
Tub Advice
by coopns. 07/22/19 02:08 PM
9688 the one size fits all for asian cars?
by jayjr1105. 07/22/19 01:20 PM
Does Edge 0w20 contain moly? Any recent voa’s?
by Stickygreen. 07/22/19 01:15 PM
QSUD 0W20 vs. 5W20 ?
by ChrisD46. 07/22/19 01:14 PM
fat tire bikes, benefit?
by 1978elcamino. 07/22/19 12:37 PM
Whole House A/C stopped cooling Trane XE1000
by Vikas. 07/22/19 12:06 PM
Pongo23, brantdw, dgwilkes, Barb, Cromwell
68735 Registered Users
119 registered members (4WD, 2015_PSD, ABerns, 01rangerxl, AandPDan, 2003f7, 12 invisible), 2,429 guests, and 23 spiders.
Topics292,247
Posts5,019,639
Members68,735
Most Online2,967
Mar 10th, 2019
Page 4 of 5 1 3 4 5
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5098330
05/07/19 12:06 PM
05/07/19 12:06 PM
Cumberland County, Pennsylvani...
Robster Offline
Robster  Offline
+1 for the ziploc bag trick. Use a gallon-size ziploc freezer bag. This is the procedure I follow:
--Loosen the filter where you can turn it by hand (but not enough to let oil leak between the filter seal and housing).
--Put the ziplog bag completely up over the filter and as far around the housing as possible, so that you can grab the filter from the BOTTOM of the bag.
--Slowly unscrew the filter (through the bag) until the oil starts draining out of the housing into the bag; let it drain until it stops (30 seconds or so).
--Continue unscrewing the filter (through the bag) until the filter falls into the bag (be ready for this).
--Hold the bag (with the filter in it) around the housing for a few more seconds until most of the oil stops dripping.
--Slowly pull the bag / filter down from the housing and dump the bag / filter into the oil drain pan.
NOTE: Leave the oil sump plug out as you remove the filter because several more ounces of oil will flow out after the filter is removed.
2017 RAM 1500 Big Horn 5.7L:PP 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-30 / Fram XG9688
2013 Victory Cross Country:Amsoil 20w-40, NAPA Gold
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5098336
05/07/19 12:11 PM
05/07/19 12:11 PM
Olathe, KS
kkreit01 Offline
kkreit01  Offline
Olathe, KS
It's not that fun, but neither are most things in life. I use a bag over the filter, and drape a PIG Form-a-Funnel (used to be a sponsor on here -- very useful item) over the steering rack. I had minimal mess.
At least we do not have to first remove 10 torx screws and an under-belly shield. I'd much prefer changing the oil on my truck vs. the last few cars I've had.
2017 Jeep Grand Cherokee 4x4 3.6: 0w20 Rotella Gas Truck/Napa Platinum filter
2018 Ram 1500 CC Hemi: 5w20 Rotella Gas Truck/Napa Platinum filter
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5098351
05/07/19 12:28 PM
05/07/19 12:28 PM
Texas
Tdog02 Offline
Tdog02  Offline
Texas
Buy a Ford 2.7 ecoboost. The easiest oil change I have ever done in my life. Cartridge filter up front and on the top. No tool required to pull the oil pan plug.
09 Venza 2.7 104k 5w-30 Magnatec
16 F150 2.7TT 52k 5w-30 Magnatec
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: Tdog02] #5098677
05/07/19 06:04 PM
05/07/19 06:04 PM
Michigan
dwcopple Offline OP
dwcopple  Offline OP
Michigan
Never, sorry.
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5099053
05/08/19 03:10 AM
05/08/19 03:10 AM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
If the filter is indeed vertical like the picture in the link shows, the solo cup method I've done on some cars might work. If a solo cup won't fit over the filter, it should still give you a general idea. Something like a cup that you can put over the filter, and squeeze it to twist the fitler off, and the cup catches the oil. I've heard of the breadbag method and ziploc bag method, but I'd prefer to use something rigid if possible.
https://www.reddit.com/r/Justrolled...joying_the_filter_location_on_a/?depth=2
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: Blueskies123] #5099336
05/08/19 10:49 AM
05/08/19 10:49 AM
NWA/SWMO
Ws6 Offline
Ws6  Offline
NWA/SWMO
Originally Posted by Blueskies123
My Acadia dumps oil all over the front motor mount. So sure enough at 45,000 miles the motor Mount failed. It is as if auto engineers have never worked on an actual vehicle.
More like, it's as if they DID...
2019 CX5 Grand Touring Reserve
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5100346
05/09/19 08:25 AM
05/09/19 08:25 AM
IL
LAGA Offline
LAGA  Offline
IL
I have a 2017. What a P I T A. I installed a Permanent- Cool oil filter relocation kit on it. The filter is not mounted on the frame up front still protected from road debris.
Four legs good, two legs better!
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: LAGA] #5100731
05/09/19 04:01 PM
05/09/19 04:01 PM
Michigan
dwcopple Offline OP
dwcopple  Offline OP
Michigan
If I was keeping this I would do that ^^^ too
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: PumpPusher] #5109019
05/19/19 05:49 AM
05/19/19 05:49 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Originally Posted by PumpPusher
On a 6.7 Cummins, you have to go through the wheel well. Once you drop the filter, you have to use one hand to balance the filter and plug the hole with a special tool at the same time. As times goes on, I care less and less how much oil I get on me, the truck, the ground, and everywhere else.
Don't plug the filter. You'll make less mess just getting it out of there.
These days, I stick a small funnel with a hose attached under it and punch a hole into the bottom of it.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5109042
05/19/19 06:50 AM
05/19/19 06:50 AM
Massachusetts
AuthorEditor Offline
Massachusetts
Many boat installations make it impossible to access the actual drain plug, or if you can the oil would flow into the bilge, which isn't good. So often the best way is to suck oil out the dipstick with some device, or some engines feature an oil removal pump--like my Perkins 4.236. On one boat I was helping out on we couldn't figure out how to change the oil filter on the generator engine. After much discussion, experimentation, and foul language we decided that the only conceivable way to remove it was to first remove the engine from its mounts. The old Crown Vic or Grand Marquis filter wasn't the worst, but it was still a pain getting at it when using ramps in the driveway. You had to have the front wheels at a slight angle in order to remove the filter, and I could never remember what angle until I was up on the ramps and crawled under to take a look. This necessitated climbing back in and racking the steering and ramps one way or the other a little bit until you could get everything at just the right angle to reach up under there and be able to remove it. I think that's one reason Motorcraft shrank the FL820S filters after awhile.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: MCompact] #5109132
05/19/19 08:47 AM
05/19/19 08:47 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Originally Posted by MCompact
Originally Posted by Delta
I'm spoiled by the top access filter on my GTI and now new to me Tacoma. More vehicles should be that easy!
My BMWs and Mini have topside mounted cartridge filters- it makes oil changes dead easy.
My BMW E90 is hands down the easiest oil change I've ever done. Literally no mess. I've been very surprised at some of the ridiculous oil changes I've done recently on a few newer cars.
2000 Jeep Cherokee 4.0L (182k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (43k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5109212
05/19/19 11:06 AM
05/19/19 11:06 AM
in the shop
sw99 Offline
sw99  Offline
in the shop
That sound as fun as the ridiculous design on the 15'-current HD Ram's with the Cummins. You get a tiny window that is barely large enough fro the filter to go in/out. Need a zip lock bar or oil cap tool so you don't make a mess. It's also [censored] near impossible to get a wrench in there also.
2008 Toyota Corolla CE 1.8L
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: Blueskies123] #5109926
05/20/19 08:11 AM
05/20/19 08:11 AM
New York City
SeaJay Offline
SeaJay  Offline
New York City
Its not their job. They are supposed to design it so it fits somewhere, does its intended purpose and is cheap to assemble at the plant. Making it easy for folks to work on the part after it leaves the factory is not part of the equation.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: SeaJay] #5110011
05/20/19 09:37 AM
05/20/19 09:37 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Exactly.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: JLTD] #5110122
05/20/19 11:41 AM
05/20/19 11:41 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I suspect you are absolutely correct . Lack of communication between engineers / departments . And the fact the biggest concern id the time / cost to assemble the car .
Once the car is sold , it is not " their " problem .
Wyr
God bless
Page 4 of 5 1 3 4 5
