Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
71 registered members (askani79705, 4WD, AndyB, cdm1993, 94astro, 7 invisible), 1,531 guests, and 18 spiders.
Topics303,499
Posts5,235,240
Members71,061
Info on Mobil1 M108A Filter #5097654 05/06/19 04:49 PM
G
GZRider Offline OP
G
Per Mobil1 tech support email the M108A uses a silicone ADBV and the bypass pressure setting is 15psi. I know Subi's like a higher pressure then that but is there any reason that would be inadequate for the G37/370z?
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097670 05/06/19 05:01 PM
CT8 Offline
What specs does the Nissan recommend?
2015 F150 2.7
2018 F350 6.2
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097676 05/06/19 05:10 PM
P
PPWarrior Offline
P
Nissan's OEM (Gonher) are no higher than you run-of-the-mill mid-range filters. In fact, I think anything on M1 EP price rage are better made.
On my Versa I use the M108-A.
It seems to be Nissan's universal measure. No issues yet. I have noticed the Early Second Gen M1 EP Filters (black can) were better built than the ones sold on late 2018-early 2019.
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097685 05/06/19 05:25 PM
sir1900 Offline
No. No reason at all.
2015 Infiniti Q50
Mobil1 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + Mobil 1 M1-108A
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097706 05/06/19 05:59 PM
slacktide_bitog Offline
Use the longer M1-110A if it will fit smile
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097725 05/06/19 06:31 PM
J
JerryBob Offline
J
I know the Fram 7317 is the larger version of the 6607, which is spec'd for my wife's Mazda. Is the M1-110A the same deal - same specs as the M1-108A, which is also spec'd for the Mazda?
Re: Info on Mobil1 M108A Filter [Re: JerryBob] #5097733 05/06/19 06:39 PM
correct
And the Wix part number is 57356
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097760 05/06/19 07:18 PM
G
GZRider Offline OP
G
I agree the larger filter from FRAM, Mobil1, WIX ect is a good option on the VQ37, and it fits fine on the 370Z/ RWD G37 but unfortunately I know from past experience it will not on the X sedan I have. I'm going run the M108A with Mobil1 5w-30 Extended Performance for 1 year but only 7500-8000 miles of 50% or more highway at most, it should have enough capacity for that. Changing the oil next weekend probably, will update in a month or two on how it worked out.
Re: Info on Mobil1 M108A Filter [Re: GZRider] #5097828 05/06/19 08:35 PM
B
bbhero Offline
B
What's the problem in regards to a sedan??
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Info on Mobil1 M108A Filter [Re: bbhero] #5099750 05/08/19 04:39 PM
DGXR Offline
I suspect the problem is not with the sedan body but rather with the X model's AWD drivetrain.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Info on Mobil1 M108A Filter [Re: DGXR] #5099948 05/08/19 07:57 PM
B
bbhero Offline
B
Of course that's understood....
If it is the same motor in a two door coupe 3.7 L motor like a G37 or say like my car the 3.5 VQ it should not matter.... The clearance issue is not there with either a 2 door coupe or a 4 door sedan.... With the same exact motor and transmission in either of them... It should not matter in all likelihood. Unless there's a real difference. An example should be like my VQ 3.5 L motor and Garak has a G37... We can both use the longer 57356 or the shorter 51358.... Or the 7317 longer vs the 6607 shorter.
