Originally Posted by PimTac
Originally Posted by zmelli
Oil weighs less at higher Altitude so you might want to step up a grade
That's a new one.
But you have to admit it was pretty good!
To expand on that further, then it's appropriate to run 0w16 or 20 in Death Valley since it's below sea level at times.
Perfect Corollary.
I think you will be fine. Check out the UOA on the 4Runner....the 1400 miles of towing was headed West from Ohio to Colorado, all high speed highway and 5th gear locked out. RPMs well above 3000 most of the way and some brutal winds blowing at times. Was using 5w-20 but don't think it would make a difference from 0w-20.
The long road trip was Colorado to Montana and back with a lot of vertical and Wyoming highway speed limit is 80mph.
If you are concerned about it then you can run a 0w- or 5w-30, many many folks on FJ Cruiser and T4R sites running 30 grades long term with no issues. I am currently running a 5W-30 and will have a UOA in a couple of months.
https://www.bobistheoilguy.com/foru...iles-2015-toyota-4runner-4-0#Post4972499
Hope that helps.
Good info! Just curious how "severe" it is in terms of load. Because heavy engine loading (towing, roof rack, etc.) are considered severe in the owner's manual. But 70 with a roof rack can't be worse than 85 with a 20mph wind, can it?
Just seems so arbitrary.
I'm sure that the oiling system is up to it..."severe" is indeed a relative term, but towing a 5000# (2267kg) at 75mph (120kph) into a 25 knot (46kph) headwind, with those results, tells me that you'll be fine with your roof rack at 85....all day long.
Wind resistance grows at a power of two with speed increase, so a few mph makes a huge difference in power required to maintain speed. So in fact, in the mountains at high speed with a headwind, your maximum speed might be limited by available engine power.
