Freedom 95 doesn't keep house worm long
by laoshanren - 10/22/19 11:36 PM
2006 Altima 2.5 oil leak
by LeakySeals - 10/22/19 10:34 PM
fishing licenses on boats
by motor_oil_madman - 10/22/19 10:16 PM
Tokyo Motor Show 2019
by PimTac - 10/22/19 10:14 PM
More Quick Chargers
by Snagglefoot - 10/22/19 09:48 PM
'08 Chrysler Sebring Test Drive
by Fifth87 - 10/22/19 08:42 PM
Testing old coolant
by ARB1977 - 10/22/19 08:20 PM
Pennzoil Maximum Power 0W30
by HoosierJeeper - 10/22/19 07:44 PM
Bought a unknown air rifle and need help.
by jakewells - 10/22/19 07:26 PM
What happens to used cars that don't sell?
by WhyMe - 10/22/19 07:11 PM
No spark
by Eric Smith - 10/22/19 06:57 PM
So you need a new engine?
by Skippy722 - 10/22/19 06:40 PM
Super Hot Fish at local fish monger restaurant
by Cujet - 10/22/19 06:39 PM
Mobil 1 5w30 SN+ D1G2 VOA
by donnyj08 - 10/22/19 06:07 PM
Shell Nitro+ Gasoline in older cars
by Building3 - 10/22/19 05:43 PM
11th UOA, 07 FJ 4.0L, Mobil Delvac 1 ESP 5w40
by jetman - 10/22/19 05:42 PM
OPG vs. NPD for parts
by 007 - 10/22/19 05:01 PM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
67 registered members (10WSmuckers, Capt, bunnspecial, 4WD, Alex_V, Blkstanger, 8 invisible), 1,284 guests, and 25 spiders.
Topics296,360
Posts5,096,302
Members69,652
Most Online3,532
Jul 30th, 2019
Page 3 of 5 1 2 3 4 5
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: PimTac] #5096780 05/05/19 06:37 PM
CR94 Online Content
Online Content
Originally Posted by PimTac
Originally Posted by AZjeff
But, if anyone thinks vehicles are designed to make anything easy for the DIY guy you might be mistaken.
It depends on the manufacturer and the model. My Mazda has a access panel that reveals the drain plug and filter with no obstructions. I’m surprised when I hear of vehicles where the entire splash shield has to be removed.
My Toyota has an access panel for oil changes, but it originally was hinged and so long that it can not clear the ground to open it unless the car is much higher off the ground than otherwise necessary. That wasn't a DIY-friendly move. Some owners deal with it by removing the entire large splash shield, which involves removing about 13 stubborn plastic push pin fasteners and several bolts.
I modified the access panel to make it easily removable, so it's completely out of the way after removing only 3 push pins and two screws.
I still have to lift the car a little, which is annoying, and wasn't necessary on my earlier cars. At least oil and filter changes are free of messy drooling on other components, as described by others in this thread.
2011 Toyota Prius now at 104K
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5096859 05/05/19 08:04 PM
dwcopple Offline OP
Bottom line, it's absurd.
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5096932 05/05/19 09:06 PM
T
Triple_Se7en Offline
T
Air filter and wiper blades might be the only replacements during a 2 year/24K lease.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097063 05/06/19 01:06 AM
P
PumpPusher Offline
P
On a 6.7 Cummins, you have to go through the wheel well. Once you drop the filter, you have to use one hand to balance the filter and plug the hole with a special tool at the same time. As times goes on, I care less and less how much oil I get on me, the truck, the ground, and everywhere else.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: Triple_Se7en] #5097111 05/06/19 05:49 AM
dwcopple Offline OP
There's no way I'm bothering with an air filter...
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097322 05/06/19 10:24 AM
A
ARCOgraphite Offline
A
Originally Posted by dwcopple
Quote
The Fumoto valve is a good idea.
It's a 2 year lease. I just might not even bother again until it's time to turn it in.
Not your car! contract says you have to maintain it properly by the book.
Do it. or suffer the slings and arrows of BITOG misfortune.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097374 05/06/19 11:34 AM
T
TiredTrucker Offline
T
Regarding the position of the drain plug, get a Fumoto drain valve and replace the stock plug. You can attach a small hose to the outlet of the valve and run it down to the pan. Or control the flow with the valve so that it doesn't shoot all over like taking out the plug. I have used Fumoto valves since the 1990's. All of my personal and commercial vehicles have Fumoto valves on them, some for the similar situation the OP has. One on my semi truck has almost a million miles of 20,000 mile oil changes. Just as good as the day I bought it and put it on.
The solution for the filter has been addressed.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097388 05/06/19 11:45 AM
G
GMBoy Offline
G
If it's like my 2016 Ram Hemi, it does make a mess. I just contain it, wipe it and spray brake cleaner and call it done. It's easier to reach from the front to get the filter, BTW.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: JLTD] #5097521 05/06/19 01:53 PM
H
hallstevenson Offline
H
Originally Posted by JLTD
I think the problem (where filters and drains plugs are in poor locations) stems from: engine design and where it fits are done by different teams with no communication between. Engines have optimal filter placement and are packaged for builders' convenience...engine builders have to fit into a size but likely aren't told what's just outside those areas.
The same engine is frequently used in different vehicles too. An automaker isn't going to have 2-3 different engine assemblies for different vehicles.
There is communication too. If there wasn't, something like an oil filter could end up in a location that's almost entirely inaccessible (not just "difficult to access"). There's just a limit to the changes that they can make to accommodate all scenarios. They do have to compromise at times....
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: PimTac] #5097529 05/06/19 02:00 PM
H
H
I've seen some with small access holes but if you start punching holes in these shields, they start losing any value. Many of these shields have a primary function of reducing noise and these holes probably end up creating more noise.
My Infiniti has a "door" but it's not too large. I haven't used it but I'm curious how much oil still hits it when the drain plug is first removed. You know how oil comes out at first, going a fair bit horizontal and slowly changes to draining more vertical ?
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: GMBoy] #5097533 05/06/19 02:07 PM
4WD Online Confused
Online Confused
The two GM L83’s I own appear thoughtful … the plug and filter are further back past all the under pans/shields.
Everything drains into the drain pan, no collusion or obstruction …
In fact there is a small steel sump attached to the aluminum oil pan so that threads are steel on steel.
Perhaps Clinebarger could advise if removing those have a utilitarian purpose ?
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097564 05/06/19 02:41 PM
A
addyguy Offline
A
Worst I owned was my 2002 Cavalier. 4-speed automatic pan 'closes off' the bottom, so the filter has to come out through the wheel well, was a heck of a job to get it out.
2010 Kia Soul 2U - 2.0L I-4, auto; 146k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5097715 05/06/19 06:21 PM
F
fdcg27 Offline
F
The oil filter is way up there and when removed, oil dumps all over a wiring harness and some steering components making a giant mess. The oil drain plug is right by the front sway bar and oil dumps all over that when draining. Simply unreal. My driveway is a mess now. I won't be doing this again. Ridiculous. Shame on the engineers.
This does sound like quite the treat.
Dumb design for sure.
I've owned many vehicles over the past forty years or so and I've had the good fortune never to have had one that made for really difficult and messy oil changes.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: ARCOgraphite] #5097776 05/06/19 07:32 PM
Corollaman Offline
Originally Posted by ARCOgraphite
My '07 Silverado 4x4 4.3 MT W/T had similar issues with poor placement of filter. Had to make up a drip tray out of disposable turkey pan. I did appreciate the molded in rubber gasket in the drain plug and cast aluminum oil pan.
My 2011 silverado 4.3 is the same, that one area under the filter is a different color from the oil changes, I figured that out after doing it myself for the first time. Plus the dealer had the drain bolt on ridiculously tight, I literally almost gave up you start to question if your turning the correct way.
Re: 2019 RAM Hemi 4x4 is the dumbest oil change I've encountered [Re: dwcopple] #5098165 05/07/19 08:32 AM
H
HangFire Offline
H
Sounds like a job for Form-a-Funnel?
Sad that maintenance is still the red headed step-child of automotive engineering.
Various musings: http://hangfire.net
