106 registered members (2015_PSD, 2012AccentSE, AlaskaMike, Alfred_B, 2011335d, 69Torino, 10 invisible),
1,979
guests, and 54
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,481
Posts5,136,322
Members70,072
Most Online3,589 Nov 2nd, 2019
Lexus parts on line or ???
#5094684
05/03/19 09:28 AM
JeffKeryk
OP
OP
Posts: 2,652 |
Dumb question... Where do you buy genuine Lexus parts? I am about to service the transmission on our old GS; I am scared of the dealership prices.
Thanks in advance. I may just get a WIX...
2018 Tesla Model 3, Medium Range Battery 2018 Lexus RX450h 2013 Lexus GS350 F Sport 2006 Acura TSX 2001 Tundra Access Cab, 1998 Accord LX, 1968 Corvette L36 Roadster, 1965 Olds 4-4-2
Re: Lexus parts on line or ???
[Re: JeffKeryk]
#5094689
05/03/19 09:31 AM
ZebRuaj
Posts: 304 |
Cross reference it back to Toyota. Then look online for said parts or go into the stealership if in a pinch.
~Shade tree mechanic for friends and family.
[Re: JeffKeryk]
#5094707
05/03/19 09:48 AM
rekit
Posts: 193 |
+1 on cross reference. A few years back I needed front control arms for my SC400. Over 700 each as a Lexus part. On the forums I found out that the same part was on the Supra-for 250! Exact same part #. Fit perfect. Lexus was great before it got a taste of US dealership games.
[Re: JeffKeryk]
#5094740
05/03/19 10:29 AM
JMJNet
Posts: 1,349 |
Some of the lexus stealership are posting in Amazon. I have got some Toyota parts from Amazon's Lexus supplier cheaper than local stealership. Amazon can sort the source by price. Who cares if the source is Toyota or Lexus dealership as long as the price is good.
- 2017 Toyota Sienna
- 1995 GMC Suburban 6.5L Turbo Diesel
[Re: JeffKeryk]
#5094757
05/03/19 10:43 AM
The Critic
Posts: 21,354 |
The Wix transmission filter kits are generic, offshore garbage.
Toyota wants crazy amounts of money for the filter and the pan gasket. If you are dropping the pan, these are the parameters you will be working with...
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30 2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
[Re: JeffKeryk]
#5094768
05/03/19 11:00 AM
BigD1
Posts: 3,378 |
You sure it needs a new filter?
On a 2006 IS350 with 150,000 miles at time of trans fluid exchange, Hendrick Lexus said the filter does not need to be changed because it was an overbuilt filter. I did pay $250 for the trans fluid exchange...12 quarts of WS.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
[Re: JeffKeryk]
#5094820
05/03/19 12:07 PM
CELICA_XX
Posts: 990 |
On the rare occasion that I need a part... I often go to the Toyota dealer because it's closer.
Although I've always been told that the Toyota system is unable to look up "Lexus specific" parts.
LX450 (Land Cruiser) I can get any part.
LS400, I cannot get anything because there is no Toyota equivalent in the US.
15 Toyota Prius - M1 EP 0w20 SN+ 06 Acura MDX - M1 EP HM 5w30 SN+ 02 Toyota ECHO - Valv MaxLife Syn 5w30 SN 97 Lexus LX450 - M1 EP HM 5w30 SN+ 93 Lexus LS400 - M1 EP HM 5w30 SN+
[Re: JeffKeryk]
#5094825
05/03/19 12:11 PM
JeffKeryk
OP
OP
Posts: 2,652 |
Thanks to all. The primary reason I wanted to change the filter was to drain as much fluid as possible. I will probably never do it again... The car has 60K, even if I did do it again it would be a simple spill and fill.
Remember, lifetime fluid, right?
Regarding the Toyota cross reference, the GS is rear wheel drive. I will get the tranny model number and check.
[Re: JeffKeryk]
#5094901
05/03/19 01:57 PM
ClarkSuper100
Posts: 29 |
I've had good luck buying genuine Lexus/Toyota parts on eBay from an actual Lexus dealership. One dealer that I have purchased from via eBay is Bell Lexus, in Scottsdale, AZ. I am about to replace my shocks and have gotten good prices from them -- cheaper than my local dealerships.
1999 RX300 89,000 M1 EP 5W30 2005 A6 59,000 Motul 8100 X-Cess 5W40
[Re: ClarkSuper100]
#5094949
05/03/19 02:46 PM
Y_K
Posts: 2,639 |
I've had good luck buying genuine Lexus/Toyota parts on eBay from an actual Lexus dealership. One dealer that I have purchased from via eBay is Bell Lexus, in Scottsdale, AZ. ... Second that. [they are sweet online, will rip you apart if you come in store] P.P.S. I doubt you will ever find genuine OE Lexus part for my LX, the generic Toyota part number for Landcruiser will work, of course, but only 5% of those pass the muster on the incoming QC check before they reach the assembly line, it's irrelevant and another story altogether.
[Re: Y_K]
#5097075
05/06/19 12:53 AM
ClarkSuper100
Posts: 29 |
[quote=ClarkSuper100]I've had good luck buying genuine Lexus/Toyota parts on eBay from an actual Lexus dealership. One dealer that I have purchased from via eBay is Bell Lexus, in Scottsdale, AZ. ... Second that. [they are sweet online, will rip you apart if you come in store] From personal experience, I concur with both of your remarks!
[Re: JeffKeryk]
#5097262
05/06/19 08:09 AM
edyvw
Posts: 8,599 |
Cross shop. I always go to dealership as I like to spend money locally. I had two regular maintenance items last two weeks with Tiguan, so first ventured to dealerships to check: 1. Coil failed on #1 cyl. Normal item on these engines for those year, and I have never switched to updated version. Went to local store to buy some cheap coil until I order on internet as on internet they had sale $26 for OE VW coil. Auto Zone wanted $42 for Bosch coil pack. Went to local dealer, $38 for updated OE VE coil. Got all four. 2. As things usually go, two days after HiD bulb dies on same car. Phillips online $49. Went to VW, $196 for the SAME bulb. Went to Toyota, since dealership is 3 miles from my home, $213 for SAME bulb. Got on Amazon, as you would expect, works like a charm (changed both bulbs).
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter). 11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
[Re: edyvw]
#5099170
05/08/19 06:53 AM
wag123
Posts: 1,770 |
[quote=edyvw] 1. Coil failed on #1 cyl. Normal item on these engines for those year 2. As things usually go, two days after, HiD bulb dies on same car. Quality VW components
[Re: wag123]
#5099213
05/08/19 07:38 AM
edyvw
Posts: 8,599 |
[quote=edyvw] 1. Coil failed on #1 cyl. Normal item on these engines for those year 2. As things usually go, two days after, HiD bulb dies on same car. Quality VW components  Yeah, they are. Toyota uses exactly same components from same manufacturer. Except, changing coil in VW takes 5min, on Toyota takes 4hrs.
