Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
101 registered members (10ecfarmer, 55hambone, alchargo, 007, 4WD, 94astro, 11 invisible), 1,284 guests, and 23 spiders.
Topics303,499
Posts5,235,265
Members71,063
Page 3 of 4 1 2 3 4
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5094205 05/02/19 08:42 PM
G
GaryPoe Offline
G
I have also read amsoil recommendations changing first fill at 10k becose of my previous statement.
2014 F150 STX 4x4 Sport, Super Cab 5.0L Coyote, OZ Omega Tuned, Leveled with 35" BFG TKO2, Banks Power Monster exhaust, jlt oil seperator 5w20 PPPP, Motorcraft fl-500-s
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5094237 05/02/19 09:07 PM
SubieRubyRoo Offline OP
Bluesubie, this is an 07 Impreza 2.5i. I've also got an 05 Outback. Other than rear suspension, mechanically they're about as close to identical as two different car models can be.
BigShug, Amsoil doesn't have anything in 20mm thread anymore that can run 25k. They're all the "cheaper" EaK filters that are only rated for 15k; I have no qualms running the FU to 25k if the UOAs show the oil can go that far.
De omnibus dubitandum.
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5094247 05/02/19 09:11 PM
B
BigShug681 Offline
B
That’s correct, my mistake got my numbers mixed up
2006 F350 DRW 6.0 PSD with a ZF6 6Speed. If you can't find it or float it then just grind it
Re: So I finally jumped on the Amsoil wagon... [Re: BigShug681] #5095310 05/03/19 11:21 PM
T
TiredTrucker Offline
T
Originally Posted by BigShug681
I believe amsoil has a synthetic media filter that can run a full 25k
But even Amsoil SS fine print says to cut the time and miles if meeting anything that qualifies as severe conditions. It is a pretty easy line to cross regarding severe service in just about any owners manual.
Just my leaving the house in any of my vehicles qualifies a severe service by both the OEM of my vehicles and Amsoil's data pages. 2 miles of gravel road to the nearest hard road.
I'll stick with Schaeffer. Good value. Good oils.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: So I finally jumped on the Amsoil wagon... [Re: TiredTrucker] #5095490 05/04/19 08:14 AM
T
Triple_Se7en Offline
T
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5096300 05/05/19 08:45 AM
K
kr_bitog Offline
K
Seems Amsoil Sulphated Ash in SS series still pose issue on modern DI engine, and I am tired with their marketing that keep promoting different weight oil for different properties.
Their NOACK for 0w20 is not that stellar as well
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5096923 05/05/19 08:57 PM
And what does that have to do with a port-injected boxer that takes a 30wt oil?
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5096949 05/05/19 09:31 PM
B
BigShug681 Offline
B
A whole lotta nothin
Re: So I finally jumped on the Amsoil wagon... [Re: kr_bitog] #5097193 05/06/19 07:56 AM
R
ridgerunner Offline
R
NOACK for 0-20 is 8.5. If that isnt good enough switch to the 5-20 which is 5.8. That is what I am doing.
Re: So I finally jumped on the Amsoil wagon... [Re: ridgerunner] #5097217 05/06/19 08:14 AM
K
kr_bitog Offline
K
I know 5w20 noack is way better, but not sure the wear and high temperature protection compared with other 20 and 30 weight. In the past i had used ss0w30 and ss0w20, but i drained early due to noticeable change of engine sound after 8k usage. Personally i will rate ss as the same class with m1 ep, even though ep thickens slower and it is cheaper.
Re: So I finally jumped on the Amsoil wagon... [Re: ridgerunner] #5097868 05/06/19 09:22 PM
My post was about 10w30, which has a NOACK of 4.1. 10W30 will run just fine during summer in anything you're running a 20wt in.
Re: So I finally jumped on the Amsoil wagon... [Re: SubieRubyRoo] #5098323 05/07/19 11:52 AM
StevieC Offline
If SA was a problem they would have lowered it when they changed the formulation for LSPI. SA is only a problem in GM engines because of their choice of inferior quality chains which lead to them inventing a new oil spec to correct instead of fixing the root of the problem. The reason other oil blenders/manufacturers lowered their SA content was for Dexos certification and they aren't going to have a separate oil just for GM. wink
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: So I finally jumped on the Amsoil wagon... [Re: StevieC] #5098700 05/07/19 06:27 PM
G
Garak Offline
G
That's hard to say, Stevie. I think they're might be a little more to it than that, on both sides of the SA level issue - the oil companies and the OEMs. Some of the synthetics we already saw didn't have excessive SA numbers in the first place. That would be those already with a magnesium additive package and other products that weren't aspiring to A5/B5 or long drains. I'll have to look through my old sheets, if I still have them, but I'm pretty sure, for instance, that Petro-Canada's pre-dexos1 gen. 2 oils in SM and SN didn't go insane on SA. On the other side of the issue, when it comes to manufacturers, at least some European manufacturers have expressed a preference by way of specification for lower SA lubes in their GDI engines, where possible, let alone TGDI.
Obviously, this is quite likely platform specific, not to mention driving style specific, and tune specific. Additionally, this is only one aspect of a specification, and Signature Series very well may have other mitigating benefits.
Plain, simple Garak.
Re: So I finally jumped on the Amsoil wagon... [Re: Garak] #5098869 05/07/19 09:02 PM
StevieC Offline
Ok I'll agree with that. smile
Re: So I finally jumped on the Amsoil wagon... [Re: StevieC] #5098931 05/07/19 10:06 PM
G
Garak Offline
G
Personally, I don't think there is anything wrong with SS or most SN type oils out there for GDI or TGDI except for certain problematic cases. You've pointed it out yourself here before, an oil specification is a not the proper solution to bad engineering. That's not to say that specs are bad and we should just all run ND 30, but the engines that have been reputed to be pickiest about oil (or other maintenance items) were simply problem children in the first place.
Page 3 of 4 1 2 3 4
