Originally Posted by Astro14
If they're under the timing belt, it's often easier to do when the timing belt is being done.
You add a half hour (water pump) to a job of several hours (timing set) - it saves you in the long run.
That's what reputable shops do but in another forum, someone with an Accord was quoted ~$500 for a timing belt replacement and ~$400 for the water pump, so $900 total. Should be more in the sub-$700 range and that's using Honda parts (water pump is typically $150-200).
