Originally Posted by Audios
You can move a lighter, more powerful lithium booster for a little more than a new battery. I used the MicroStarts for a while (125$) but after I burned a few out I found this cheapie on Amazon. I bought the extended warranty also, and its started a BMW 740i with no issues.
https://smile.amazon.com/Imazing-Portable-Car-Jump-Starter/dp/B07GLSCLHP/ref=sr_1_fkmrnull_3?crid=1BDY5SI2AKYA7&keywords=imazing+jump+starter&qid=1556466841&s=gateway&sprefix=imazing+ju%2Caps%2C132&sr=8-3-fkmrnull
Mine is the 1200a, I dont see it. It was 50$ on sale.
No, that's the dirty little secret AKA fraud. A few years back, the SLA battery boxes started fraudulently rating their cranking amps, using same battery and cables, (which is pretty much all they are to the extent of jumping duty) suddenly they were claiming 50%, 100%, even 200% more cranking amps.
Next along came the Chinese with no reservations about fraud at all, with their Li-Ion packs that can only deliver 1/4 to 1/2 as much current yet they claim 500% even 1000% more cranking amps than they can deliver.
Want to know the true cranking amps? Read the battery (not jump box) manufacturer spec sheet. You can exceed that rating for the short duration of a jump, but the fact is that if your jump pack were putting out 1200A, it would instantaneously melt and burn.
Apparently consumer protection laws went out the window when amazon and ebay came along.
