Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
United Airlines Boeing 757-200 Blows Tires at Newark
by john_pifer. 06/15/19 03:41 PM
15w40 or synthetic 10w30 for 115°f temps
by leroyd92. 06/15/19 03:29 PM
napa 10% code
by eljefino. 06/15/19 02:23 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
76 registered members (bbhero, aquariuscsm, Alfred_B, AdditiveOCD, 5AcresAndAFool, alteredtuning990, 8 invisible), 1,564 guests, and 25 spiders.
Topics290,254
Posts4,987,108
Members68,412
Most Online2,967
Mar 10th, 2019
Any easy way to cook plantains? #5093717
05/02/19 11:36 AM
05/02/19 11:36 AM
Suburban Washington DC
atikovi Offline OP
atikovi  Offline OP
No frying. Does baking or boiling give good results? I turn to this for my occasional craving but wonder if making it myself fresh is an option.
[Linked Image]
Re: Any easy way to cook plantains? [Re: atikovi] #5093728
05/02/19 11:45 AM
05/02/19 11:45 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
They can be baked. An interesting combination is slices baked in salsa. Yum
Rod
Re: Any easy way to cook plantains? [Re: atikovi] #5093746
05/02/19 12:03 PM
05/02/19 12:03 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
I have no experience with this product, only with the whole plantains. Unless these are very inexpensive I don't see why you would buy it instead, plantains are very inexpensive if you live along a trade route that regularly deals with them, like about as cheap as bananas depending on region since they are not as popular in the US as bananas.
Anyway you can cook them just about any way you like. Like any other food, boiling tends to give the worst texture, I would sooner steam them if all you have is a pot of water. Microwave works about the same, cover them to trap the steam and cook on half power for twice as long as directed.
Baking/roasting or toaster oven gives better texture but be sure you oil the pan or do them on lower temperature with a non-stick pan. That's with fresh plantains, since these are already fried maybe no oil is needed to keep them from sticking. Although those pictured must have ripened so they are sweet, they have too high a water content to get much carmelizing going on with the sugar in them but you can get some if the temperature is high enough, and yet since they are already fried I wouldn't want to cook much above 420F as that's just below where many oils start to oxidize and turn carcinogenic.
I wonder why not fried since they are already fried (stated on box) so you may not be able to get any more oil into them which would make it little if any less healthy than other methods but again I would just get the whole fresh plantains instead.
Also if you get them fresh, if you cook before they are ripe they are more of a general starch you can use like potatoes, have not turned nearly as sweet yet.
Fresh can also be grilled various ways (whole open, whole in aluminum foil, thick cut coins on a skewer with or without other food aka kebobs) but those little pre-cut things in the box, I don't know if they'd fall through a grill grate, but you should still be able to grill them in aluminum foil, essentially steaming them.
You can cut up chunks to put in soup in place of potatoes... but potatoes, including sweet potatoes, may also be less expensive, especially whole ones not convenience-food boxed ones. I imagine the closet food experience to those would be sweet potatoes aka yams so seek recipes for sweet potatoes, or of course... plantains. wink
Re: Any easy way to cook plantains? [Re: Dave9] #5093774
05/02/19 12:33 PM
05/02/19 12:33 PM
atikovi Offline OP
atikovi  Offline OP
About $2. The convenience is worth it. Already fried and ready to heat up in the micro. 3 or 4 pieces with dinner or as a snack is great. And I don't have cooking oil and don't want to deal with it after use or to store it. Plantains were on sale at 3/$1 which is why I asked.
Re: Any easy way to cook plantains? [Re: atikovi] #5093779
05/02/19 12:39 PM
05/02/19 12:39 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
If you just want to heat them in a microwave, you can do that with fresh plantains, it just takes a bit longer in the microwave, and the 20 seconds to cut them in slices like those are. If your microwave has food presets, set for same # of potatoes but remember to cover them to keep some steam in.
No [cooking] oil? That is a foreign concept to me, even if I didn't fry there are uses like pasta or salad dressings/etc.
If you only use enough oil to improve the surface area contact with pan rather than deep frying, it is not so much a loss to throw away any tiny amount remaining in the pan, so you don't have to store it. I just put food on a paper towel after cooking to get some oil off then wipe the pan with the paper towel. That goes in the trash rather than washing it down the drain to later contribute to clogs.
30% of calories in a healthy diet should be fat, with many vegetable oil being the healthier type... just don't heat it above its oxidation temp. Meh I am drifting, away, off topic, sorry lol.
Re: Any easy way to cook plantains? [Re: atikovi] #5093795
05/02/19 01:00 PM
05/02/19 01:00 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
For very ripe ones (i find them the best flavored), peal and slice down the middle lengthwise. bake with a little brown sugar and cinnamon powder.
Delicious.
2018 KIA Sportage 2.4 AWD:
Carquest Full Syn 5W-20, Carquest Prem 85334
2013 Hyundai Santa Fe Sport 2.0T:
Quaker State Ultimate Durability 5W-30, OEM
Re: Any easy way to cook plantains? [Re: atikovi] #5093811
05/02/19 01:15 PM
05/02/19 01:15 PM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
La Caretta in south FL is very good.
Lots of food for the money. ☺
Re: Any easy way to cook plantains? [Re: Mr Nice] #5093814
05/02/19 01:19 PM
05/02/19 01:19 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Right around the block.
slobber
Re: Any easy way to cook plantains? [Re: atikovi] #5093866
05/02/19 02:16 PM
05/02/19 02:16 PM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
Re: Any easy way to cook plantains? [Re: atikovi] #5094474
05/03/19 06:20 AM
05/03/19 06:20 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Mofongo !!!
If it's the truth....it can handle the pressure !!!
Re: Any easy way to cook plantains? [Re: atikovi] #5094827
05/03/19 01:15 PM
05/03/19 01:15 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
As a kid I was a pearl diver in a sea food restaurant. One of the sides were banana fritters. Deep fried quarters of whole banana dropped into the Fryolater. They were great. grin2
Thick oil is better grin2
Re: Any easy way to cook plantains? [Re: atikovi] #5095018
05/03/19 05:17 PM
05/03/19 05:17 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
My dad used to fry them in butter,cinnamon,and sugar.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Any easy way to cook plantains? [Re: atikovi] #5095306
05/03/19 11:13 PM
05/03/19 11:13 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
I call titi Gladis, she sends muduros, mofongo, pasteles, or acapurrios over.
You get what you pay for...
So keep in mind how much you paid for this advice.
