Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Ollie_B_2000, akarip, BJD2020, ToyTaco2002, EarlT500
70802 Registered Users
107 registered members (Anduril, 2015_PSD, 4WD, 2009Edge, alchargo, 28oz, 8 invisible), 1,971 guests, and 15 spiders.
Topics301,940
Posts5,205,933
Members70,802
Page 2 of 2 1 2
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5094648 05/03/19 08:44 AM
Snagglefoot Offline
+1 on the Fender flares. Go ahead and repair the rust to the best of your ability and if it looks bad, throw the flares on. Neighbour just put a set on. Looks good.
If you want the job done right......do it yourself.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5094660 05/03/19 08:59 AM
01rangerxl Offline
If the rust is bad enough to eat through the body, the truck had to have come from a Northern state. You may want to check things like the condition of the rear spring shackles, bumper mounting area, fuel tank straps, etc. before proceeding with repairing cosmetic issues.
It's usually pretty hard to find a replacement bed that is a good color match...even if the color is the same it's probably going to be noticeable that the bed has been changed without some paint work, at the very least a good buffing. Replacing the bed would be a good opportunity to clean up the frame on the truck and make any necessary repairs to the parts I mentioned above though.
There's probably nothing to lose by trying your fiberglass idea except some time and cost of materials if it doesn't work out. I'd just spray paint the finished repair.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: Jethro_Bob] #5094695 05/03/19 09:34 AM
J
JLTD Offline
J
Originally Posted by Jethro_Bob
At my local pick and pull a truck bed no lights or tailgate runs $150 plus tax. Idk about your area, but it might be a good option to look into.
That was my first thought also, a donor vehicle.
Lates.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5094778 05/03/19 11:07 AM
E
earlyre Offline
E
check with your local "career center/Vocational School/etc" they usually have an auto body program, and need vehicles for the kids to work on.
They normally have heavily discounted labor costs...
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5094875 05/03/19 01:20 PM
N
NDL Offline OP
N
I hate not replying to each person individually, as I appreciate the time that each person has taken in offering a solution. I thank y'all for sharing your ideas.
Contacting the area vocational college was a great suggestion, but I had already done that, and they don't do body work on donor vehicles unfortunately.
The flares sounded like the best solution, but I didn't run with that, because I had seen flares costing several hundred dollars. Yet one poster (on this thread) came in around $150, which makes it a worthwhile solution.
The other thing is to patch it with fiberglass, and yes, maybe give the paint a whirl myself.
Again, thanks to all for your time.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5094971 05/03/19 03:26 PM
N
nthach Offline
N
If the local pick-your-part yard is nearby and having sale or has decent pricing, I'd look for a cancer-free bed and do a meticulous job rustproofing it with Fluid Film or the like.
If you don't care about aesthetics, you can patch it, what you can also do is use fiberglass cloth with some foil tape as a backing and try your best to contour to the panel. Build up the glass layers and use some kitty hair filler or plain-jane Bondo for final finishing and prime/paint it.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5095061 05/03/19 05:02 PM
DuckRyder Offline
[Linked Image]
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: DuckRyder] #5095085 05/03/19 05:37 PM
N
NDL Offline OP
N
That's a great suggestion, thank you
Originally Posted by DuckRyder
[Linked Image]
Bingo! That's exactly what I was looking for...thank you!
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5095290 05/03/19 09:53 PM
G
GMBoy Offline
G
Search car-part.com and see if there is a good whole bed available in your color. Probably be about $500 and an hour or two to change it out. I just swapped out a bed for a guy's 2000 S10 pickup and we found the same color used in good condition for $500 and when swapped looked like it belonged there all the time...paint age and normal wear was all the same.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: GMBoy] #5095873 05/04/19 06:37 PM
N
NDL Offline OP
N
Thank you for your suggestion, which I will take into consideration
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5095947 05/04/19 07:56 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I wouldn’t do fiberglass since it’s an exposed, visible part. If it were in the bed I’d think differently.
I’d suck it up with getting a patch welded in and paint reasonably well matched. Or else I’d let it rot and be saving for a new truck. It all depends upon how much you like the truck...
The replacement bed is a great idea, but it’s a lot of logistics to make it work... I’d consider that option first honestly, but you could waste a lot of time in search and I don’t know that it’s a great use of your time unless there’s a bunch of pick and pulls or used parts distributors around.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: JHZR2] #5096119 05/04/19 11:06 PM
N
NDL Offline OP
N
I thank you for both your time and opinion.
Swapping beds is more work than what I want to get into right now...do you have any idea what a welder would charge to weld a patch into the quarter panel? The patch itself runs $55 plus shipping, and if I have it welded into place, it would be a big improvement over what I have currently.
The other question would be: how would I treat the welds? I know that I would have to grind them down, but what method would be most effective?
Thanks in advance
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5096276 05/05/19 07:19 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Thanks in advance
It’s not the welding and welds that are the issue. It’s the prep and paint after. A pickup bed shouldn’t have much in the way of closed off areas; notionally accessing from behind once done to treat, paint, etc. should be straightforward. It’s getting it to look reasonably presentable that’s the challenge.
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5096292 05/05/19 07:39 AM
DuckRyder Offline
To some extent the answer depends on exactly where the rust is and how bad.
My Ranger has a partial wheelhouse inside the fender. It extends from the lip to the inner bedside in the area above the wheel. I’d hazard a guess that this is where the rust is from it becoming packed with mud, snow, salt and other detritus and not getting cleaned out. I suspect this partial wheelhouse will need to be repaired as well. Is this included in the patch panel?
It's also possible you could avoid the welding entirely and install this patch panel using Lord Fuzor or similar panel bonding agent.
Still, you are going to have several hundred dollars (and at least a day labor) in this by the time you have done it.
IMO the replacement bed of same color and flares are both more expedient, and possibly more cost cost effective solutions. Particularly if you could find used OE flares off of a sport or edge.
Robert
Re: :::Thoughts (Should I Put In For A New Quarter Panel?) [Re: NDL] #5097371 05/06/19 10:30 AM
N
NDL Offline OP
N
Thanks to all who replied.
You have all given me much to think about, and if I go ahead with any kind of repair, I will post the results on this thread (should any future poster look to do a similar repair).
Again...thanks to all who shared their knowledge and time.
Page 2 of 2 1 2
