Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
Best solution for crack in vinyl seat
by paulri. 06/18/19 07:50 PM
Lower Tier Interstate batteries @ Costco?
by Onetor. 06/18/19 07:46 PM
75W90 suggestions?
by WillB. 06/18/19 07:37 PM
Big R - Mag1 Synthetic $12.99
by RamFan. 06/18/19 07:30 PM
No title after 2.5 months?
by Shaman. 06/18/19 07:18 PM
Downgrade Windows 10?
by Robster. 06/18/19 07:17 PM
AC PF2257G Any good?
by Oldtom. 06/18/19 06:48 PM
New tire time...225/55/19, all seasons...
by Ws6. 06/18/19 06:48 PM
Rockauto Code
by Recalculating. 06/18/19 06:27 PM
Side Mirror Partially Stuck
by ET16. 06/18/19 06:15 PM
2010 Honda Odyssey leak in trunk area
by Donald. 06/18/19 06:01 PM
DTS419, chakir, 9J460, Petethedog, RenewableLubeBen
68429 Registered Users
56 registered members (AnthemBassMan, ajchien, AC1DD, BlakeB, chemman, 7 invisible), 1,295 guests, and 28 spiders.
Topics290,642
Posts4,990,068
Members68,429
Most Online2,967
Mar 10th, 2019
Why doesn't NAPA carry Motorcraft wheel cylinders? #5094606
05/03/19 09:01 AM
05/03/19 09:01 AM
USA
slacktide_bitog Offline OP
USA
The only one they carry is their house brand which I think is Raybestos.
I think the WC is frozen because I can't get the drum around the shoes. I tried loosening the parking brake all the way, and the drum still won't go over the shoes!
Nobody carries the Motorcraft WC locally, only the respective house brands (Napa, Autozone, and AAP). Chinese wheel cylinders probably suck, and I don't want to do this again
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094618
05/03/19 09:12 AM
05/03/19 09:12 AM
MA
AandPDan Offline
AandPDan  Offline
MA
Did you back off the self adjusters?
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094637
05/03/19 09:27 AM
05/03/19 09:27 AM
Albany NY
ted s Offline
ted s  Offline
Albany NY
you do know motorcraft doesnt make parts
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094656
05/03/19 09:55 AM
05/03/19 09:55 AM
Canada
nobb Offline
nobb  Offline
Canada
Your adjusters are probably not set correctly. If it really is the wheel cylinder, there's no need to go OEM on this part. Any high quality brake manufacturer like Raybestos or Centric is perfectly capable of making a decent wheel cylinder. There's not much to this part...it's just a hydraulic piston.
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: ted s] #5094688
05/03/19 10:30 AM
05/03/19 10:30 AM
USA
USA
Yes I know that, but the Motorcraft WC is made in Italy and includes new bolts
all the others are Chinese of questionable quality mad
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: AandPDan] #5094690
05/03/19 10:32 AM
05/03/19 10:32 AM
USA
USA
I'm not replacing the shoes. I am replacing only the drum because of a bad wheel bearing (the Mk1 Focus rear wheel bearing and hubs are built into the drums)
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094694
05/03/19 10:33 AM
05/03/19 10:33 AM
USA
USA
Now I have another problem. The bolts are all rusted! There is no way to get them off! One of them crumbled on me
Motorcraft includes new bolts with their WC, while the others don't
I went and bought a WC at AAP. It is Chinese and likely rebranded Raybestos, judging by the part number. It includes a new bleeder screw, but not the other bolts.
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094704
05/03/19 10:45 AM
05/03/19 10:45 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Italian made vehicles have a pretty bad rap ...
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094726
05/03/19 11:04 AM
05/03/19 11:04 AM
USA
USA
My only option now is to sand down the shoes until I can fit the drum around them, or take the shoes off completely and have only three brakes until I can have it done somewhere
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094754
05/03/19 11:41 AM
05/03/19 11:41 AM
CA
The Critic Offline
The Critic  Offline
CA
Drill out the bolts? Try a 90-deg drill if possible?
2011 Toyota Prius 1.8L - 190K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: Miller88] #5094791
05/03/19 12:24 PM
05/03/19 12:24 PM
California
nthach Offline
nthach  Offline
California
Nothing wrong with Brembo hydraulics, and I think Continental(ATE) has a plant in Italy.
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094812
05/03/19 12:55 PM
05/03/19 12:55 PM
northern Alabama
benjamming Offline
benjamming  Offline
northern Alabama
I realize this doesn't help about the bolts, but Rabestos may make a wheel cylinder repair kit. I used that on my '94 Grand Am. They were also USA made.
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094815
05/03/19 01:01 PM
05/03/19 01:01 PM
Apple Valley, California
Chris142 Online content
Chris142  Online Content
Breakfast he bolts off with a chisle.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: Chris142] #5094821
05/03/19 01:08 PM
05/03/19 01:08 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Sure.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Why doesn't Motorcraft carry Motorcraft wheel cylinders? [Re: slacktide_bitog] #5094837
05/03/19 01:32 PM
05/03/19 01:32 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The only wheel cylinders I have ever stocked are for an Escape and Taurus. Other than that they are not worth giving shelf space, especially when I can get them same day or overnight. I have gone over a year without selling them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
