by tenderloin - 02/27/20 09:59 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
Sony MEX-GS820BT, good AM/FM?
by sasilverbullet - 02/27/20 05:59 PM
What Is This ?
by Propflux01 - 02/27/20 03:39 PM
Million parts struts
by ram_man - 02/27/20 03:10 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
58 registered members (blufeb95, bbhero, AZjeff, carlprop, amauri, 3 invisible), 1,328 guests, and 22 spiders.
Topics302,023
Posts5,207,413
Members70,819
Help with no-start Echo blower #5093147 05/01/19 07:10 PM
Cressida Offline OP
My ES-2100 Echo blower will no longer start. I have spark, fuel and good compression (?) but can't get it to run even for a few seconds (doesn't make sense). I've done all that I can think of and would like to see if there are any more ideas before I give up on it. The new hand held blowers don't have the power of the old units so I'd like to keep this one around...
It was running last fall but now it just seems to sometimes sputter but only for a few combustion strokes. It NEVER starts or develops any power or running even for a few seconds.
I have visually checked the spark and it seems good, but I've changed the plug anyway. So I think the spark is ok.
Moving on to fuel, I originally thought it wasn't getting fuel so replaced ALL the lines. A new carb was put on late last year and probably doesn't have 3 hours of run time on it. I've taken the carb out of the equation by putting gas and / or sprayed starting fluid into the carb and even removed the plug to spray directly in the chamber and still can't get it to hit (fire). I've tried different gas even. This seems pretty strange.
I checked compression and I am getting up to 180 psi before it levels out. Doesn't that seems too high? Most small 2 cycles I think are around 100-120 psi. Even though I'm showing very good compression is it telling something that I don't understand?
Anything that I'm overlooking or should check would be welcome.
Re: Help with no-start Echo blower [Re: Cressida] #5093151 05/01/19 07:16 PM
R
Rand Offline
R
clogged exhaust?
Re: Help with no-start Echo blower [Re: Rand] #5093166 05/01/19 07:29 PM
G
gman2304 Online Content
Online Content
G
Originally Posted by Rand
clogged exhaust?
. This. There’s a small screen in the muffler that could be carboned up. Clean by heating with a small torch. Also could need a new air filter.
Re: Help with no-start Echo blower [Re: Cressida] #5093192 05/01/19 08:06 PM
T
tomcat27 Offline
T
I'm thinking that you need to check the carb - if it ran last fall
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Help with no-start Echo blower [Re: Cressida] #5093231 05/01/19 08:52 PM
Dinoburner Offline
Check for air leaks esp the carb mounting bolts.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Help with no-start Echo blower [Re: Cressida] #5093317 05/01/19 10:43 PM
Dave9 Offline
When I am frustrated with a 2 cycle engine, I check the shaft nut, the nut on the impeller in your case, to make sure it's tight enough to do what I do next...
Hook up a beefy cordless drill or impact wrench or driver, make sure you're spinning it the right direction, and give it some revolutions while spraying carb cleaner in.
It's not runtime on the new carb so much as whether fuel gummed up after that point, but one thing is for sure, that if this is the first start of the season you don't want to frustrate yourself doing it all via a pull cord instead of getting power tools involved. wink
Re: Help with no-start Echo blower [Re: Cressida] #5093438 05/02/19 05:40 AM
V
vwmaniaman Offline
V
Check the carb and head bolts. Check the exhaust screen. Iwas taught this trick: drain the fuel tank, put 1/4cup of Seafoam in it and let it sit for 5 min or so. Pump the primer bulb till you see fuel in it. Finish filling the tank with fuel this time. Prime it a couple times and turn on the choke. Hold the throttle open all the way and pull the cord. It should start now if you have good spark. Always works on my stuff.
Don't waste your time on a slipshod repair.
Re: Help with no-start Echo blower [Re: Cressida] #5093740 05/02/19 10:57 AM
9
97prizm Offline
9
Check the in tank fuel filter. I had one of these that got really dirty along with a dirty air filter
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Help with no-start Echo blower [Re: gman2304] #5094175 05/02/19 07:06 PM
Cressida Offline OP
clogged exhaust?
This was it. thumbsup
That small screen was carboned up completely. I heated it with a torch and then wire brushed it clean and the engine is now starting and running with full power. I still haven't gotten the idle adjusted to where it will idle without stalling. I think I will replace that intake gasket b/t the carb and cylinder because maybe extra air is getting drawn in there and that might explain why I can't get my low speed adjustment screw to give enough fuel to maintain an idle.
I was pulling on that cord way too much (Dave9). My right shoulder is so sore I can hardly lift my arm above my head now. crazy
Re: Help with no-start Echo blower [Re: Cressida] #5097793 05/06/19 06:51 PM
R
Rand Offline
R
you can remove that screen its just a safety nanny so you don't start a forest fire.
