113 registered members (Aero540T, Alfred_B, alarmguy, 2015_PSD, 53' Stude, 2012AccentSE, 11 invisible),
1,797
guests, and 67
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,478
Posts5,136,268
Members70,072
Most Online3,589 Nov 2nd, 2019
Amsoil SS 0-20, 4,000 miles, 94’ Ford Ranger 4.0, 15 months
#5093885
05/02/19 01:45 PM
ridgerunner
OP
OP
Posts: 914 |
4 qts Amsoil SS 0-20, 1 qt Amsoil SAE30. Ran for 1 yr 3 months. Engine has 90,070 miles on it. 4,000 miles on oil. Engine is 94’ OHV 4.0. Driving is short trips in winter, longer trips during warmer weather, lots of off road and dirt roads. Engine calls for 5-30. I did not change oil yet. I drained one qt out for sample and added one qt of Amsoil SS 10-30. Should I change oil or no?
Iron 17 Lead 5 Copper 3 Aluminum 3 Silicon 10 Sodium 99 Potassium 52 (flagged for possible coolant)? Mg 600 Calcium 1234 Phos. 629 Zinc. 800 Moly. 148 Boron. 41 All others less than 1
Visc. 9.8 TBN. 3.5
Re: Amsoil SS 0-20, 4,000 miles, 94’ Ford Ranger 4.0, 15 months
[Re: ridgerunner]
#5093893
05/02/19 01:54 PM
addyguy
Posts: 14,906 |
Except for the potassium, I'd say it looks great and leave it in.
BUT, if it is contaminated with coolant, I'd change it out ASAP.
Once you get the coolant leak(?) fixed, 2 years could be possible easily.
2010 Kia Soul 2U - 2.0L I-4, auto; 149k miles. Castrol Edge (black bottle) 5W-30; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles. Oil/filter TBD
[Re: ridgerunner]
#5093913
05/02/19 02:22 PM
JLTD
Posts: 3,049 |
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
[Re: ridgerunner]
#5093916
05/02/19 02:26 PM
oil_film_movies
Posts: 4,672 |
Sodium & potassium both are high, signature for a slight coolant seep into the oil.
[Re: ridgerunner]
#5093920
05/02/19 02:31 PM
ridgerunner
OP
OP
Posts: 914 |
Thinking the SS 10-30 added some TBN. Was thinking running it for the summer and changing it out this fall before winter. What do ya think about that? Btw, never added any oil.
[Re: ridgerunner]
#5093970
05/02/19 03:05 PM
addyguy
Posts: 14,906 |
You need to find out why coolant is getting into the oil.
[Re: ridgerunner]
#5094075
05/02/19 05:15 PM
ridgerunner
OP
OP
Posts: 914 |
Agreed but do not want to tear into the engine. It runs perfectly now would hate to tear it down for such a tiny tiny possible leak. I am not above rebuilding the engine once torn down but seems extreme to me...or am I wrong? I haven’t noticed a leak or have not needed to add coolant. IDK.
[Re: ridgerunner]
#5094120
05/02/19 05:51 PM
oldhp
Posts: 2,302 |
Not using anti-freeze no problem. Maybe shorten the OCI to a year with 5W30 in it and see what it does.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod" "When others cut you down, remember where they came from." "I don't run...........I just wait"
[Re: ridgerunner]
#5094186
05/02/19 07:19 PM
andyd
Posts: 8,562 |
How is the frame? Spring and shock mounts? I would love to find a 125" wheelbase frame for the Rat. The 4.0 has an intake manifold gasket issue. The Rat's 4.0 is the best part of the whole blame truck  PS. @ 90K miles, The internals of the 4.0 shouldn't need a rebuild
'16 Camry LE STP synth 0w20 and STP filter. the Fridge 1994 Ranger ,the Rat, 5w30 dino, STP filter '16 Camry SE, Valvoline HM 0w20 and OEM filter Thick oil is better
[Re: ridgerunner]
#5094187
05/02/19 07:21 PM
ridgerunner
OP
OP
Posts: 914 |
I used SS 0-20 just to see what it would do in all my 3 vehicles. 2013 subie it worked ok but burned 1.5 qts per the one yr OCI. Still got one more to sample in a month or two, my 2010 Dodge 5.7 Hemi will be next. It too drinks the SS. I may just put in a group 2 or 3 in this Ranger next and call it good. Just wanted to see how 0-20 did is all.
[Re: andyd]
#5094189
05/02/19 07:24 PM
ridgerunner
OP
OP
Posts: 914 |
How is the frame? Spring and shock mounts? I would love to find a 125" wheelbase frame for the Rat. The 4.0 has an intake manifold gasket issue. The Rat's 4.0 is the best part of the whole blame truck  I got lucky! No rust anywhere on this 94’. The frame and all underneath looks like it came from the factory when I bought it in 2013. Got a small rust spit on the tailgate now is all. My wheelbase is 108”, single cab, shortbox manual 4.0.
[Re: ridgerunner]
#5094213
05/02/19 07:48 PM
demarpaint
Posts: 33,556 |
I'd pressure test the cooling system to rule out the possibility of a bad head gasket.
God Bless Our Troops
[Re: ridgerunner]
#5095177
05/03/19 07:23 PM
StevieC
Posts: 25,017 |
I wouldn't be using 20wt oil in a 1994 engine that calls for 30wt.
Does your report show Glycol and is it at 0. Glycol would be present in that vehicle if it truly were coolant, although the Sodium and Potassium is high enough that I would think it is coolant.
The Amsoil formulation since they changed it to the LSPI formulation does have some minor amounts of sodium in it but certain not as high as your UOA.
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1 '06 Santa Fe - 535k KM (Retired) There is no such thing as "lifetime" fluids!
[Re: ridgerunner]
#5095192
05/03/19 07:40 PM
ridgerunner
OP
OP
Posts: 914 |
As stated I did add one qt of Amsoil SAE 30. Not sure if that contains sodium or potassium 🤷♂️
[Re: ridgerunner]
#5095197
05/03/19 07:44 PM
StevieC
Posts: 25,017 |
As stated I did add one qt of Amsoil SAE 30. Not sure if that contains sodium or potassium 🤷♂️ None of their formulations to my knowledge have Potassium. Some have minor amounts of sodium though.
