Motorcraft Spark Plugs on Ebay?
by panthermike - 10/14/19 04:25 PM
Change Fram Ultra with 720 hours on it?
by CharlieBauer - 10/14/19 04:02 PM
Powerstop Brake kits
by RhondaHonda - 10/14/19 03:00 PM
Oil recommendations
by Speak2Mountain - 10/14/19 02:28 PM
Maxlife ATF
by charmer37 - 10/14/19 02:18 PM
Anyone want a NAPA GOLD 1334 and FRAM ULTRA 3593A
by 53' Stude - 10/14/19 01:59 PM
Sams Choice Cuban Style Mustard
by skyactiv - 10/14/19 01:55 PM
Front suspension still making noise
by A_A_G - 10/14/19 01:20 PM
What is this? It says SmartGear
by JLawrence08648 - 10/14/19 12:20 PM
2004 Toyota Sienna
by Char Baby - 10/14/19 11:48 AM
Installing your own winter tires
by Snagglefoot - 10/14/19 10:43 AM
2018 Subaru Forester Premium 11mo Review
by badtlc - 10/14/19 10:40 AM
Good price on Mobil 1 Delvac 75w-90?
by kehyler - 10/14/19 09:09 AM
Ford IDI diesel starters
by bullwinkle - 10/14/19 09:07 AM
Portable Induction Bolt Heater
by billt460 - 10/14/19 06:51 AM
Coil springs, is there a top and bottom?
by LeakySeals - 10/14/19 06:20 AM
Non-DPF engine oil in Diesel BMW F10
by L93013 - 10/14/19 04:00 AM
Mercedes, Worth It?
by rrretiree7 - 10/14/19 02:30 AM
HotelPrisoner, Germanium, ffr1222k, Laurie, messerschmitt
69554 Registered Users
93 registered members (14Accent, Alfred_B, alchargo, 2015_PSD, 67ZL1, 7 invisible), 2,326 guests, and 33 spiders.
Topics295,962
Posts5,088,208
Members69,554
Most Online3,532
Jul 30th, 2019
Page 1 of 5 1 2 5
Tire pressure help #5093642 05/02/19 10:37 AM
E
Env1ous Offline OP
E
Hi all, so I have a 2013 F150 and replaced the tires with a set of Cooper Discoverer ATP tires in 275 /70 R18 E Range tire (Since finding bigger tires in anything else is difficult)
I know E range have a different PSI requirement than the typical LT rated tires. I have mine aired up to around 48 PSI. Is that too much for daily driving? Ride does seem a little stiff and it takes bumps hard. I know it will have more feedback than an LT tire. I just want to make sure my tires last a long time!
p.s. Does anyone else have these? Are they a little loud on the road?
Re: Tire pressure help [Re: Env1ous] #5093653 05/02/19 10:45 AM
G
gfh77665 Offline
G
Your answer is right there.
Drop 5 PSI and drive for a week to test.
Re: Tire pressure help [Re: gfh77665] #5093656 05/02/19 10:48 AM
E
Env1ous Offline OP
E
Thanks for the quick reply! Will do. Rather ask people with experience. I looked on forums and got so many different answer. It was making my head spin!
Re: Tire pressure help [Re: Env1ous] #5093686 05/02/19 11:08 AM
M
MParr Offline
M
Just a reminder; a load range E tire is standard for 3/4 ton trucks. With a 3/4 ton truck tire, it’s going to be a a harder ride. Fill to the pressure on the door sticker.
2019 VW Tiguan SE Now: Mobil 1 ESP 5W30 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Tire pressure help [Re: Env1ous] #5093697 05/02/19 11:18 AM
das_peikko Offline
What does it say on the tire for the maximum? I always go 4 PSI below the maximum on the tire.
Re: Tire pressure help [Re: das_peikko] #5093698 05/02/19 11:20 AM
E
Env1ous Offline OP
E
80PSI max. LOL Not going to 76. Don't need it that high. I just saw the max on it.
Re: Tire pressure help [Re: gfh77665] #5093700 05/02/19 11:21 AM
J
JLTD Offline
J
Agree....and also watch for any developing wear patterns....center wear = overinflated, edge wear (rear) underinflated. Expect a little edge wear on the fronts...but that'll be taken care of with rotation.
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Tire pressure help [Re: Env1ous] #5093712 05/02/19 11:30 AM
O
OVERKILL Online Content
Online Content
O
IIRC, the "proper" method for determining pressure is to use the load tables.
There's info about this on CapriRacer's site:
http://www.barrystiretech.com/
If you go to the load tables and see that your factory P-rated tires which were, for the sake of this example, 275/60R18s and spec'd 35psi, which results in a load rating of 2,403lbs, we then need to de-rate them by 10% to account for a P-rated tire on a truck/SUV, which results in a 2,185lb rating.
This is actually documented here:
https://www.toyotires.ca/sites/default/files/application_of_load_inflation_tables_20170203.pdf
So, you look at the load table for the LT tires, which is, for your size, down on page 23, and we see that for a 275/70R18 we need 40PSI to achieve roughly the same weight rating.
So, find your factory tires in the P-metric list, find their weight rating, derate them by 10%, and that will give you the the minimum value you need to shoot for when choosing a pressure for the LT tires.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Tire pressure help [Re: das_peikko] #5093758 05/02/19 12:15 PM
R
RamFan Offline
R
Why?
18 Giulia Ti Sport Q4
  • 2.0T I4 - 18k - PP Euro LX 0w30 - Mobil 1 - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 64k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Tire pressure help [Re: RamFan] #5093815 05/02/19 01:19 PM
Q
Quattro Pete Offline
Q
Why?
Because that's what he was told by a "reliable source" smirk2
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5057191/tire-pressure
Just ignore him. He's trolling as usual.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Tire pressure help [Re: OVERKILL] #5093819 05/02/19 01:28 PM
E
Env1ous Offline OP
E
After looking. It says around 45psi. I think I am currently around 50. So I will decrease and see how 45psi feels and look at tire wear. I saw something called the calk test, to make sure the inflation looks good?
Re: Tire pressure help [Re: das_peikko] #5093824 05/02/19 01:32 PM
K
Kibitoshin Offline
K
Didn't you read the post?! They are Load Range E tires which means they have a 80PSI maximum pressure and you are recommending 76PSI?!
When I went to from P to an LT my tire shop (which referenced Toyo's inflation tables) recommended 45PSI front and rear.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Tire pressure help [Re: Env1ous] #5093829 05/02/19 01:41 PM
JohnnyJohnson Offline
If you want a soft ride don't buy E rated tires.
2004 Corolla 136143
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76552
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Tire pressure help [Re: JohnnyJohnson] #5093839 05/02/19 01:53 PM
E
Env1ous Offline OP
E
Don't want a soft ride. But when I hit bumps my rear kicks out on me. So I was more so wondering if I had them over inflated and I do. So it does hit bumps a little stiffer than it should
Re: Tire pressure help [Re: Env1ous] #5093854 05/02/19 02:05 PM
sloinker Online Shocked
Online Shocked
Inflate them to recommended factory pressure if they are the correct tire size and load range. It seems the last set of E range tires on Ford pickup I owned was 51 psi front and 60 psi rear. That was a 1990 F-250 4x4 diesel. Your results may vary...
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Page 1 of 5 1 2 5
