Outlander Plug-in Hybrid EV
by Snagglefoot - 11/12/19 03:30 AM
Slick 50
by rrretiree7 - 11/12/19 01:19 AM
Need Spring Compressor OTC 6494?
by Wolf359 - 11/12/19 12:48 AM
2009 Accord V6 terrible MPG
by JEL01 - 11/11/19 11:04 PM
How to fix exhaust broken at the flange?
by slacktide_bitog - 11/11/19 10:53 PM
Bugs Bunny
by red7404 - 11/11/19 10:40 PM
Keep with Conventional for 2001 Buick?
by JGmazda - 11/11/19 09:44 PM
Air Compressor Stalling
by spasm3 - 11/11/19 08:57 PM
1977 2-stroke moped ESSO 2-T 18:1?
by N8conn - 11/11/19 08:50 PM
*NEW* DELO 600 ADF
by SavagePatch - 11/11/19 07:48 PM
2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30
by Colt45ws - 11/11/19 07:24 PM
Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
Scuder, Jasonrmcc, Capacc, allofoil, Chizzle
69837 Registered Users
28 registered members (AZjeff, dlundblad, FastLane, emod, Alex_V, 4 invisible), 666 guests, and 21 spiders.
Topics297,297
Posts5,112,483
Members69,837
Most Online3,589
Nov 2nd, 2019
Page 2 of 3 1 2 3
Re: under valve cover pics 363k miles [Re: bullwinkle] #5092401 05/01/19 05:52 AM
E
Ed_Flecko Offline
E
Originally Posted by bullwinkle
It is a Panther chassis, there are many Crown Vic PIs that went through police service & have ran big miles in taxi service (which I'm guessing is the case here?).
You are correct. The Crown Vic is a surprisingly durable car!
smile
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092411 05/01/19 06:01 AM
A
atikovi Offline
A
Towncars use that engine and limos routinely go 400 or 500K miles. There was one on Ebay a while back with over 700,000 miles.
Re: under valve cover pics 363k miles [Re: double vanos] #5092416 05/01/19 06:07 AM
M
Miller88 Offline
M
I thought everyone in Dubai ran 20w50 in everything!
On a more serious note - looks good. How's the interior holding up? Does it all crack?
Originally Posted by double vanos
M/C did a good job! It looks like the passenger side had a little more varnish than the drivers side. Hotter on that side maybe?
I believe that's the oil pumps through the driver's side first then to the passenger side head. The oil passages on that side are very small, too.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: under valve cover pics 363k miles [Re: bullwinkle] #5092447 05/01/19 06:45 AM
F
ford46guy Offline
F
My main question is-are they the original timing chains & guides? Also, why did the cam need to come out? Valve seal replacement?
No need to remove cams for VS seals., I did it on my Tbird (pretty much exact engine under the intake manifold). There is a tool to tilt the valves.
That mileage isn't spectacular. I know some cabs upstate here pushing 500K. Original everything. They are 98-02 (you can tell by the dished wheels). The transmissions have the drain pan with the plug.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092466 05/01/19 07:09 AM
Z
ZZman Offline
Z
I only have 151,000 miles on my GM 4.6. Are you telling me I can never get rid of this car as it will run forever?
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092486 05/01/19 07:30 AM
E
emmett442 Offline
E
Passenger side is the "dirty" side of the PCV system. All of the vapors and blowby flow through that side, hence the darker color. Driver's side is the clean side, which only sees air from the filtered air intake pulled through it. Difference in color between banks is normal.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092551 05/01/19 08:25 AM
PimTac Offline
The op has 363,000 miles on this car yet some try to downplay it. Only on BITOG.
Looks good.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092552 05/01/19 08:26 AM
Y
Y_K Offline
Y
Keep in mind that fuel formulation there is different from ours in the States. I have never saw a Police Inerceptor in taxi service after police abuse going over 250k on 5-20 without smoking.
The OP has been doing very well. Just keep your eye on the rear axles and bearings: that year had some bad ones, and the design is half-assed
Re: under valve cover pics 363k miles [Re: Y_K] #5092564 05/01/19 08:36 AM
E
emmett442 Offline
E
Originally Posted by Y_K
Just keep your eye on the rear axles and bearings...and the design is half-assed
Design is half assed? Based on what? It's the exact same design as every other semi-float axle over the last century.
Re: under valve cover pics 363k miles [Re: emmett442] #5092568 05/01/19 08:40 AM
I
Ifixyawata Offline
I
Leaf springs are more safe and reliable. No need of new-fangled 'coil springs' or 'control arms'.
/s
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer)
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
Re: under valve cover pics 363k miles [Re: PimTac] #5092569 05/01/19 08:41 AM
I
Ifixyawata Offline
I
Looks good.
Could be at 500k by now if 10w-40 was used.
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092586 05/01/19 08:54 AM
J
JLTD Offline
J
Looks like normal wear...seal it back up and go for another 363!
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092609 05/01/19 09:15 AM
csandste Offline
Combo of old style, lazy large displacement engines and new oils (even with some group II) are a combo that will allow you to drive forever. Nice!
2017 Kia Soul Plus-- VWB 5w30 (+ Harvest King Syn) 68,500 miles
Re: under valve cover pics 363k miles [Re: Dubai_guy] #5092612 05/01/19 09:17 AM
K
KrisZ Offline
K
Looks very good. Thanks for sharing.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: under valve cover pics 363k miles [Re: csandste] #5092638 05/01/19 09:54 AM
L
Lolvoguy Offline
L
approved
The high-strung, ubiquitous 1 and 2 point whatever, turbo(and super)-charged engines of today will NEVER reach these miles without at least one complete rebuild.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Page 2 of 3 1 2 3
