When I last bought a new car I found the tire pressures well north of 40 psi while the door placard recommended 32 psi. I was told at the time that the manufacturers typically set new car tire pressures high to accommodate shipping conditions (?).
So now I just bought a new Nissan Altima 2.5 SL and sure enough the tire pressures are high again, all four at 45 psi vs a placard pressure of 33 psi. I reset them to 36 psi.
Do all car manufacturers routinely set tire pressures that much higher than the placard pressure? If so, why? If related to shipping, then shouldn't the dealer reset the pressures to the placard pressure?
