Originally Posted by noclutch
Need to brush up on the acronym stickie!!
Originally Posted by Shannow
Here's another blender who used to frequent the site
Originally Posted by bobbydavro
Hi
It's an interesting one. Certainly no guarantee of 0W being achieved but without knowing the oils it's difficult. Often PPDs are universal across an additive suppliers range. But if you had two oils with different DI, PPD and VII you might cause problems with used oil. Even if Ccs is ok for 0W
MRV can also run into problems when certain VMs are combined with other PPDs.
In my own car I will only top up with oils using the same additive system. (Diff grade can be ok if I'm desperate ) but I want to ensure no issues. (Eg silicates and sulphonate detergents mixing are not ideal either)
No Probs...in order of appearance
PPD - Pour Point Depressants...modify wax crystals so that they can't join together at low temperatures.
DI (Package) - Detergent Inhibitor Package
VII - Viscosity Index Improver
CCS - Cold Cranking Simulator (like HTHS, but at -25 to -40C)
MRV - Mini Rotary Viscometer - simulates the ability for the oil to get to the pump through the pickup tube
VM - Viscosity Modifiers
Originally Posted by D1dad
Sorry but I've mixed different brands and weights for years with no adverse effect. My diesel gets 10-30 winter and 15-40 summer, different brands. All may cars get whatever is on sale and different top up oils in between, including whatever weight I have on hand.
Basically the same as the SAE paper...if it's going to mess things up, it's probably at teh cold end of things.
The new performance standard on BITOG of "I did it for years and nothing blew up" is hard to replicate under SAE, ASTM, and OEM standards, so they have to resort to far more technical and standardised processes
