Toyota Sienna FWD in Snow / Ice
by tiredguy - 11/19/19 09:32 AM
7.62 x 39 Top Three?
by CCI - 11/19/19 09:30 AM
MOTUL Specific VW 508.00 Unboxing
by ARCOgraphite - 11/19/19 09:14 AM
A few Ford part number filters cut open
by mpgo4th - 11/19/19 09:08 AM
Battery warranty Issue at Pep Boys
by InhalingBullets - 11/19/19 08:35 AM
How Often To Use CRC IVC ?
by ChrisD46 - 11/19/19 03:28 AM
SEARS: 4 Stroke/Lawnmower Maintenance Deals
by GumbyJarvis - 11/19/19 02:17 AM
Pepboys Coupon
by Xeno - 11/19/19 02:12 AM
Pennzoil “Designed for Your Drive”
by LubeFiner - 11/19/19 02:09 AM
Ebay $15 of $75 purchase
by GMguy84 - 11/19/19 12:06 AM
How thorough are coolant flushes at auto shops?
by Whammo - 11/18/19 10:58 PM
Fixed Orifice PCV design and issues.
by Talent_Keyhole - 11/18/19 10:44 PM
Redline Si-1 turning the light out
by lukejo - 11/18/19 10:16 PM
Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
Joe_Cena, MickWK, DaveOilStack, spiffy63, WhiteMega1227
69911 Registered Users
108 registered members (4WD, Aichiguy, 69GTX, 53' Stude, 5azzmonkey, 2004tdigls, 11 invisible), 1,842 guests, and 25 spiders.
Topics297,624
Posts5,119,560
Members69,911
Most Online3,589
Nov 2nd, 2019
Unknown ELC in cast iron diesel - how to proceed #5089939 04/28/19 09:02 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
My 82 MB 300CD turbo diesel had an orange Rotella ELC of some sort when I bought it out in LA, CA. I used the rest in a maintenance routine around 2013. The car has sat since then due to kids, but I want to start driving it again...
OE coolant was G-05, now superceded to G-48. I’m not a huge fan of going to G-48 due to the 2-eha. Ive had a lot of these cars that all keep original cooling systems on Oe coolant. They all have aluminum radiators and the nitrite content of g-05 hasn’t been an issue over 35+ years, so... I’d rather take continued chances with nitrite than 2-eha in the nitrite free g-48.
I have no reason to think poorly of the ELC, I just don’t know what I have. It seems that there are many types of ELC and EC-1 coolants out there, even under the rotella name. The stuff in my car is a pleasant, solid orange color. It may well be a gen-1 ELC that has 2-eha in it. But I’d rather not, if possible.
So, any opinions on what to do? I just got some G-05 on sale at Napa. I’m thinking of going to JD Coolguard II in my 91 350SD. But the 82 is not a mixed metal engine, so...
My 240D (one less cylinder) runs G-05. I’d prefer to have at least the 240d and 300cd on the same coolant, but in reality another coolant in the garage isn’t a big deal given that I already have Dex, g-05, g-48 and Honda blue...
Rotella ultra ELC? G-05 via a lot of draining and refilling? Cool guard II? Something else?
Thanks!
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5089966 04/28/19 09:31 PM
W
Warstud Offline
W
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5090055 04/29/19 12:50 AM
F
FordCapriDriver Offline
F
I would go with G-05
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5090993 04/29/19 07:05 PM
R
roadrunner1 Offline
R
Just use the CoolGard II and you'll know you are safe
'15 F350 6.7
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5094284 05/02/19 08:46 PM
B
BlakeB Online Content
Online Content
B
Peak Final Charge is Nitrate and 2-eh free and does not require SCA’s. It’s premixed 50/50 and only $12.xx/gallon at Walmart. You can get full strength, but WM has 50/50 red.
Walmart has the red version, but it’s avaialble in yellow as well.
https://www.peakhd.com/wp-content/u...e%20%20Red_Spec%20Sheet_hires.pdf?x38462
https://www.peakhd.com/wp-content/u...ellow_Spec%20Sheet_0215_hires.pdf?x38462
Re: Unknown ELC in cast iron diesel - how to proceed [Re: BlakeB] #5095501 05/04/19 07:25 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Thanks., wonder how it is cat EC-1 rated yet nitrite free.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5096138 05/05/19 12:02 AM
B
Online Content
B
Re: Unknown ELC in cast iron diesel - how to proceed [Re: BlakeB] #5096349 05/05/19 08:41 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
That says it meets, but doesn’t address nitrite specifically. Iirc, a range is stated in EC-1.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5096879 05/05/19 07:18 PM
G
Garak Offline
G
Just for interest's sake, you may want to take a look at Shell's document portal. They have something like three or four HD ELC type coolants under Rotella, and you mentioned them in your original post, and one of them might suit your fancy.
Plain, simple Garak.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: Garak] #5099003 05/07/19 10:46 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I did, and even contacted them. Rotella Ultra looked good, but Imwas told it is being discontinued. They were pushing Rotella NF though it has 2-EHA.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5099046 05/08/19 01:27 AM
G
Garak Offline
G
Ah well, that doesn't help. Maybe a fair bit of the Ultra might be available at a distributor, at least to keep you going for a while. wink G-05 is always an easy option, but I'm beginning to wonder about its availability, too, with both Mercedes and Ford changing things up.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: BlakeB] #5099870 05/08/19 05:51 PM
B
Online Content
B
Actually I can’t read, it’s nitrite free, not nitrate free.
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5099956 05/08/19 07:04 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Nitrites are the bad ones for aluminum. My system has aluminum in it...
Actually, just got 6 gallons of JD Coolguard II because it was recommended for my 350SD mixed metal engine. So I’m going to use that in both the SD and my 300CD. I have enough G-05 in stock to use that in my 240D for another few changes...
Re: Unknown ELC in cast iron diesel - how to proceed [Re: Garak] #5099962 05/08/19 07:11 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Yeah, G-05 long term availability was one thing on my mind. Seems like JD Coolguard II is the (IMO) rightful replacement for G-05 as it is a low Silicate Antifreeze HOAT with new-tech OATs, excellent corrosion protection, and no 2-EHA.
The 2-EHA was a great part of my concern. My 350SD was really well maintained. The HG hadn’t breached into the combustion chamber. In being well kept, it had G-48 in it as that’s what the MB 325.0 sheet now lists (vs G-05 which it used to). G-48 is nearly identical but it has 2-EHA. Could my HG have a silicone seal that was breached?
So now I’ll use the same coolant for two if not three of my diesels, keep Dex in my S-10, Honda in the Hondas, and G-48 I my BMW... unless I go cool-Gard there too!
Re: Unknown ELC in cast iron diesel - how to proceed [Re: JHZR2] #5099968 05/08/19 07:16 PM
G
Garak Offline
G
Yes, fortunately JD can be relied upon for some of these things over the years. I haven't been in the Walmart auto section for so long, I'm not even sure how much G-05, if any, is still available there, and if it's only premix, or what. Generally speaking, we do okay up here, since there are obvious problems in providing premix only coolants in our climate. You do a real flush and fill without a concentrate, January and February could get very interesting.
