JHZR2
Staff member
Anyone use this?
https://www.wd40specialist.com/pdf/specialist-spray-lubricant-2015.pdf
Don't think there's much in common with WD-40 but may be wrong. Got it to try on car hinges.
It comes out in a big foamy clump but quickly reduces down to a thick liquid as the carrier (propane?) flashes off.
It seems easy to manipulate and use. Perhaps a straight weight oil doped with some MoS2 would be better for hinges, just drop it in...
But overall I think this stuff is good because it's not so thick and messy like grease, but also gives you about 30 seconds before it sets up, so it's nice to use in hardness to reach spots.
